Using SerialLogHandler makes the Photon disappear from USB serial
I’m trying to debug some irritating crash issues, and I was hoping to get some logging out of the Photon via USB Serial. However, if I use the SerialLogHandler, the Photon disappears from my list of serial ports. I’m on Mac OS X El Capitan.
This works:
  Serial.println("loop");
However, the following does not:
  SerialLogHandler handler(LOG_LEVEL_TRACE);
  Log.trace("loop");
If I flash the device with the above code, the serial device ( /dev/cu.usbmodem1411) disappears from the list visible in the Dev serial monitor. I’ve tried a few different serial monitors, including the Photon CLI tools, and all of them report that the device just isn’t there.
Is there something I’m missing? Should I be instantiating the handler differently? Am I completely misunderstanding how the SerialLogHandler works?
Ugh, stupid mistake. I just need to declare the handler outside the setup function.
  Log.trace("loop");
Thank you for posting your answer!
