I’m trying to debug some math values using SerialLogHandler but noticed that the CLI outputs the serial monitor data just fine until I hit a delay() call…
here are the relevant code details;
SerialLogHandler LogHandler(LOG_LEVEL_TRACE);
Log.trace("i can see this just fine");
Log.trace("...this also...");
servo.write(255);
Log.trace("...this as well...");
delay(5000);
Log.trace("but not this");
This is what I see on serial output…
Is this a bug in the OS? I have no other serial functions going on at all, it’s just a simple servo control sweeping the range from 255 to 0 with a delay between.
Just a quick update… I tried Serial.write instead and got the same results…
Serial.write("i can see this just fine");
Serial.write("...this also...");
servo.write(255);
Serial.write("...this as well...");
delay(5000);
Serial.write("but not this");
servo.write(0);
delay(5000);
Serial.write("or this");
Just to confirm it's the delay command, I commented them out and I get all expected output, though my servo doesn't move at all because it's starting at 0 and the commands are sent to it one immediately after the other.
//position needle at 0
servo.write(255);
//delay(5000);
servo.write(0);
//delay(5000);
Log.trace("or this");
Sure.. the init SerialLogHandler LogHandler(LOG_LEVEL_TRACE); is literally the first line, just above void setup()
The other calls are in setup.. the sweep motion of the servo is a one-time init kind of thing..
// preload the countdown to trigger immediately on boot
countdown = millis() - periodMillis;
// attaches the servo on the D0 pin to the servo object
servo.attach(D0);
// Subscribe to the integration response event
Particle.subscribe("hook-response/netsales", myHandler);
//position servo at 0
servo.write(255);
//delay(5000);
servo.write(0);
//delay(5000);
I was advised to move that stuff out of setup by a friend just now, so I tried doing that by declaring a bool initDone = false; above setup (not in setup) and in loop() I put;
if (not initDone) {
servo.write(255);
delay(5000);
servo.write(0);
delay(5000);
initDone = true;
Ok… a bit of a breakthrough… the length of the delay matters apparently. I set the first delay to 1ms and while my servo didn’t move, I got both lines of output following both delay statements;
if (not initDone) {
needle.write(255);
delay(1);
needle.write(0);
delay(5000);
initDone = true;
So… I figured ok… put a pre-emptive delay(1); in there…
if (not initDone) {
needle.write(255);
delay(1);
delay(4999);
needle.write(0);
delay(5000);
initDone = true;
So… ok… I figure maybe delay(1); has to happen and then some other code needs to execute… then maybe it will work?
if (not initDone) {
needle.write(255);
delay(1);
Log.trace(".. 1ms ..");
delay(4999);
needle.write(0);
delay(5000);
initDone = true;
if (not initDone) {
needle.write(255);
delay(1);
needle.write(255);
delay(4999);
needle.write(0);
delay(5000);
initDone = true;
So I guess… back to the code that works but the servo doesn’t…
if (not initDone) {
needle.write(255);
delay(1);
needle.write(0);
delay(5000);
initDone = true;
