I have #include "Particle.h" and SerialLogHander logHandler(LOG_LEVEL_INFO); in my code; however, I get the following error when particle compile photon2 in my project directory:
src/christmastree24.cpp:39:1: error: 'Log' does not name a type; did you mean 'log'?
39 | Log.info("GatorDot init");
| log
Log does not appear to be defined in my scope.
Does your project have a project.properties file in the top level directory? (It can be empty.)
Did you Particle: Configure Project for Device?
These two things are necessary for Intellisense to be activated, which is what causes the edit-time warnings.
The Particle CLI compile command separate and its settings are not used for Intellisense.
I am using particle-cli .
Yes:
particle.properties
name=christmastree24
#assetOtaDir=assets
dependencies.gatordot=0.1.0
I am not sure. I created it with particle project create
That error came from compile time (via project compile photon2).
Sorry, I misunderstood your original issue. Could you share more of the .cpp file?
UPDATE
Through some experimentation, I figured out that Log is not defined prior to setup().
I have also learned that Log.info() calls in setup are not seen on the monitor as it doesn't start logging until ~2400 ms.
Correct, Log is a statement you can add inside functions - like setup() or loop().
If you want to get all logs from the start, you can add this inside setup(), right at the beginning:
waitFor(Serial.isConnected, 5000);
delay(1000);
Best,
system
Closed
January 19, 2025, 8:19am
7
