Seen safe mode triggered twice. It never completes booting.
{"name":"spark/flash/status","data":"started ","ttl":60,"published_at":"2017-08-12T01:25:22.044Z","coreid":"58003f000f51353338363333"}
{"name":"spark/status","data":"offline","ttl":60,"published_at":"2017-08-12T01:26:10.686Z","coreid":"58003f000f51353338363333"}
{"name":"spark/status","data":"online","ttl":60,"published_at":"2017-08-12T01:26:12.033Z","coreid":"58003f000f51353338363333"}
{"name":"spark/status/safe-mode","data":"{\"p\":6,\"m\":[{\"s\":16384,\"l\":\"m\",\"vc\":30,\"vv\":30,\"f\":\"b\",\"n\":\"0\",\"v\":7,\"d\":[]},{\"s\":262144,\"l\":\"m\",\"vc\":30,\"vv\":30,\"f\":\"s\",\"n\":\"1\",\"v\":100,\"d\":[]},{\"s\":262144,\"l\":\"m\",\"vc\":30,\"vv\":30,\"f\":\"s\",\"n\":\"2\",\"v\":100,\"d\":[{\"f\":\"s\",\"n\":\"1\",\"v\":100,\"_\":\"\"}]},{\"s\":131072,\"l\":\"m\",\"vc\":30,\"vv\":26,\"u\":\"153790B1DF94A332C290930076EFF123B0CB9D87AC11619491D58B6120185C80\",\"f\":\"u\",\"n\":\"1\",\"v\":4,\"d\":[{\"f\":\"s\",\"n\":\"2\",\"v\":108,\"_\":\"\"}]},{\"s\":131072,\"l\":\"f\",\"vc\":30,\"vv\":0,\"d\":[]}],\"f\":[],\"v\":{}}","ttl":60,"published_at":"2017-08-12T01:26:13.902Z","coreid":"58003f000f51353338363333"}
The reported symptom is that it stays purple status light.
I’ve realised that particle-cli was out of date, and this prior post suggests particle update via DFU mode is the fix. Is there any other way to remotely trigger the appropriate update? I did particle-cli update, tried particle compile again, tried flashing that and it does trigger an update but goes back to safe mode.
Any words of wisdom?
PS, I’ve got fingers crossed that the response isn’t along the lines of ‘if particle update their cloud firmware and you don’t update particle-cli but then flash a device it will brick it’
