I am using an Argon…I exported a Web IDE project down to my local space and compiled it for debug…So far so good…Then I pushed the Mode and Reset switches, released Reset then released Mode on the Argon board. I then hit the Run tab at the top of the page. The IDE successfully puts it into DFU mode then it errors out with the following:
If I click to show error the terminal says ‘No problems have been detected in the workspace’…If I click on debug anyway I get an error as it says it cannot find the .elf file…
