[RESOLVED]Web IDE - not verifying/compiling!
Am suffering from the following whilst trying to verify an application:
“The server has failed to process the request on time. Please try again.”
As this was a new program, I loaded the Tinker example, same issue…
Problem is with v0.6.0.rc2 firmware; v0.5.2 works…
That seems to keep happening regularly now - I’ve paged Particle again
Thanks @ScruffR. They don’t call it “bleeding edge” for nothing!
This might be a side effect of releasing 0.5.3 to be the new default - although I’ve not seen the Release Update Thread updated yet :wink:
Not sure if there is a clue here or not, but it seems that this problems occurs on a Saturday night (my time)…
@UMD sorry for this downtime. We’ve identified the problem and everything should work now!
@ScruffR this time it was a different problem. Each time we’re fixing the edge case so it won’t happen again :wink:
@suda, confirmed - case closed with thanks.
