Anyone know where I can find the dimensions for the relay shield (including mounting holes, not just length and width)? I’d like to design an enclosure to 3D print. Thanks in advance.
Are you referring to this shield: https://docs.particle.io/datasheets/photon-shields/#relay-shield-specifications-v3-x-x-
If there’s a need i can measure the height for you
Oh that’s perfect! I was looking through documentation and couldn’t find that diagram. Thanks so much for the help (although I feel a bit foolish now)!
Did you get around to designing that enclosure? I’m looking for one myself.
I did the back plate and realized it was too wide for my printer. If I get some time this weekend I may go ahead and mock up the walls and lid. If I get it done and posted, I’ll update this thread.
