Hello, I’m using the Particle Tracker One device and I’m using the tracker-edge firmware (v18). I tried to setup a regLocPubCallback like this:
int publishCallback(CloudServiceStatus status,
JSONValue * rsp_root,
const char * req_event,
const void *context);
Tracker::instance().init();
Tracker::instance().location.regLocPubCallback(publishCallback);
Tracker::instance().loop();
const void *context) {
Log.info("==== Publish callback executed ====");
return 0;
My problem is that this callback is executed only once, at the first publish. I’d like it to run for all location publishes. Am I missing something? I tried with the regLocGenCallback and I don’t have that issue.
Thanks in advance.
