I found an old robot I made that uses the old Spark Core (now renamed Photon I believe?) and I would like to connect it to a new WiFi IP.
The Core was programmed to not connect to the cloud with #include "spark_disable_cloud.h" so I could use it without internet connection, and from my notes it seems I could set a new WiFi access point over USB serial with: spark setup wifi with the Core in dfu mode.
I tried downloading the old spark-cli source but it wouldn’t compile. The new particle-cli can’t see the Core when it’s connected via USB in dfu mode (blinking yellow), I tried this on two separate machines, windows and mac. dfu-util l does find it though:
Found DFU: [1d50:607f] ver=0200, devnum=13, cfg=1, intf=0, path="20-2", alt=1, name="@SPI Flash : SST25x/0x00000000/512*04Kg", serial="8D7F54764854"
Found DFU: [1d50:607f] ver=0200, devnum=13, cfg=1, intf=0, path="20-2", alt=0, name="@Internal Flash /0x08000000/20*001Ka,108*001Kg", serial="8D7F54764854"
I’m out of ideas - anyone know what else I could try?
Merry xmas btw!
