RCswitch complie error
Does anyone else have any compiling error with RCSwitch library?
I’m just using the example code * [ReceiveDemo_Advanced.ino] and I get following errors
lib/RCSwitch/RCSwitch.cpp:250:12: invalid conversion from 'char' to 'char*' [-fpermissive]
lib/RCSwitch/RCSwitch.cpp:323:12: invalid conversion from 'char' to 'char*' [-fpermissive]
lib/RCSwitch/RCSwitch.cpp:388:20: invalid conversion from 'char' to 'char*' [-fpermissive]
lib/RCSwitch/RCSwitch.cpp:408:20: invalid conversion from 'char' to 'char*' [-fpermissive]
and this is the raw
Processing  receivedemo_advanced.ino
Checking library RCSwitch...
Installing library RCSwitch 2.5.2 to lib/RCSwitch ...
Library RCSwitch 2.5.2 installed.
make -C ../modules/photon/user-part all
make[1]: Entering directory '/firmware/modules/photon/user-part'
make -C ../../../user
make[2]: Entering directory '/firmware/user'
Building cpp file: src/receivedemo_advanced.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-6-msrc/
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F2XX -DPLATFORM_THREADING=1 -DPLATFORM_ID=6 -DPLATFORM_NAME=photon -DPLATFORM_GEN=2 -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD006 -DUSBD_PID_CDC=0xC006 -DSPARK_PLATFORM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb --specs=nano.specs -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=6 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=2.1.0 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../hal/inc -I../hal/shared -I../hal/src/photon -I../hal/src/stm32f2xx -I../hal/src/stm32 -I../hal/network/util -I../hal/network -I../hal/src/photon/api -I../hal/src/photon/include -I../hal/src/photon/wiced/security/BESL/host/WICED/ -I../hal/src/photon/wiced/security/BESL/include -I../hal/src/photon/wiced/security/BESL -I../hal/src/photon/wiced/security/BESL/crypto -I../hal/src/photon/wiced/WWD/include/ -I../hal/src/photon/wiced/platform/include/ -I../hal/src/photon/wiced/platform/GCC/ -I../hal/src/photon/wiced/security/BESL/supplicant/ -I../hal/src/photon/libraries/crypto -I../hal/src/photon/libraries/daemons/DNS_redirect -I../third_party/miniz/miniz -I../platform/shared/inc -I../platform/MCU/STM32F2xx/STM32_USB_Host_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_OTG_Driver/inc -I../platform/MCU/STM32F2xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F2xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F2xx/CMSIS/Include -I../platform/MCU/STM32F2xx/CMSIS/Device/ST/Include -I../dynalib/inc -Isrc -I./libraries -Ilib/RCSwitch/src -I. -MD -MP -MF ../build/target/user/platform-6-msrc/receivedemo_advanced.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DBOOTLOADER_SDK_3_3_0_PARTICLE -DPARTICLE_DCT_COMPATIBILITY -DSPARK_PLATFORM_NET=BCM9WCDUSI09 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSER_FIRMWARE_IMAGE_SIZE=0x20000 -DUSER_FIRMWARE_IMAGE_LOCATION=0x80A0000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSION=6 -DMODULE_FUNCTION=5 -DMODULE_INDEX=1 -DMODULE_DEPENDENCY=4,2,2101 -DMODULE_DEPENDENCY2=0,0,0 -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -fcheck-new -flto -ffat-lto-objects -DPARTICLE_COMPILE_LTO_FAT -std=gnu++14 -c -o ../build/target/user/platform-6-msrc/receivedemo_advanced.o src/receivedemo_advanced.cpp
receivedemo_advanced.ino: In function 'char* bin2tristate(char*)':
receivedemo_advanced.ino:39:10: warning: address of local variable 'returnValue' returned [-Wreturn-local-addr]
receivedemo_advanced.ino:19:8: note: declared here
receivedemo_advanced.ino: In function 'void output(long unsigned int, unsigned int, unsigned int, unsigned int*, unsigned int)':
receivedemo_advanced.ino:64:5: warning: 'Spark' is deprecated: Spark is now Particle. [-Wdeprecated-declarations]
In file included from ../wiring/inc/spark_wiring.h:50,
                 from ./inc/application.h:42,
                 from src/receivedemo_advanced.cpp:1:
../wiring/inc/spark_wiring_cloud.h:512:19: note: declared here
  512 | extern CloudClass Spark __attribute__((deprecated("Spark is now Particle.")));
Building cpp file: lib/RCSwitch/src/RCSwitch.cpp
mkdir -p ../build/target/user/platform-6-mRCSwitch/src/
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F2XX -DPLATFORM_THREADING=1 -DPLATFORM_ID=6 -DPLATFORM_NAME=photon -DPLATFORM_GEN=2 -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD006 -DUSBD_PID_CDC=0xC006 -DSPARK_PLATFORM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb --specs=nano.specs -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=6 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=2.1.0 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../hal/inc -I../hal/shared -I../hal/src/photon -I../hal/src/stm32f2xx -I../hal/src/stm32 -I../hal/network/util -I../hal/network -I../hal/src/photon/api -I../hal/src/photon/include -I../hal/src/photon/wiced/security/BESL/host/WICED/ -I../hal/src/photon/wiced/security/BESL/include -I../hal/src/photon/wiced/security/BESL -I../hal/src/photon/wiced/security/BESL/crypto -I../hal/src/photon/wiced/WWD/include/ -I../hal/src/photon/wiced/platform/include/ -I../hal/src/photon/wiced/platform/GCC/ -I../hal/src/photon/wiced/security/BESL/supplicant/ -I../hal/src/photon/libraries/crypto -I../hal/src/photon/libraries/daemons/DNS_redirect -I../third_party/miniz/miniz -I../platform/shared/inc -I../platform/MCU/STM32F2xx/STM32_USB_Host_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_OTG_Driver/inc -I../platform/MCU/STM32F2xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F2xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F2xx/CMSIS/Include -I../platform/MCU/STM32F2xx/CMSIS/Device/ST/Include -I../dynalib/inc -Isrc -I./libraries -Ilib/RCSwitch/src -I. -MD -MP -MF ../build/target/user/platform-6-mRCSwitch/src/RCSwitch.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DBOOTLOADER_SDK_3_3_0_PARTICLE -DPARTICLE_DCT_COMPATIBILITY -DSPARK_PLATFORM_NET=BCM9WCDUSI09 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSER_FIRMWARE_IMAGE_SIZE=0x20000 -DUSER_FIRMWARE_IMAGE_LOCATION=0x80A0000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSION=6 -DMODULE_FUNCTION=5 -DMODULE_INDEX=1 -DMODULE_DEPENDENCY=4,2,2101 -DMODULE_DEPENDENCY2=0,0,0 -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -fcheck-new -flto -ffat-lto-objects -DPARTICLE_COMPILE_LTO_FAT -std=gnu++14 -c -o ../build/target/user/platform-6-mRCSwitch/src/RCSwitch.o lib/RCSwitch/src/RCSwitch.cpp
lib/RCSwitch/src/RCSwitch.cpp: In member function 'char* RCSwitch::getCodeWordB(int, int, bool)':
lib/RCSwitch/src/RCSwitch.cpp:250:12: error: invalid conversion from 'char' to 'char*' [-fpermissive]
  250 |     return '\0';
      |            char
lib/RCSwitch/src/RCSwitch.cpp: In member function 'char* RCSwitch::getCodeWordC(char, int, int, bool)':
lib/RCSwitch/src/RCSwitch.cpp:323:12: error: invalid conversion from 'char' to 'char*' [-fpermissive]
  323 |     return '\0';
      |            char
lib/RCSwitch/src/RCSwitch.cpp: In member function 'char* RCSwitch::getCodeWordD(char, int, bool)':
lib/RCSwitch/src/RCSwitch.cpp:388:20: error: invalid conversion from 'char' to 'char*' [-fpermissive]
  388 |             return '\0';
      |                    char
lib/RCSwitch/src/RCSwitch.cpp:408:20: error: invalid conversion from 'char' to 'char*' [-fpermissive]
  408 |             return '\0';
      |                    char
../build/module.mk:286: recipe for target '../build/target/user/platform-6-mRCSwitch/src/RCSwitch.o' failed
make[2]: *** [../build/target/user/platform-6-mRCSwitch/src/RCSwitch.o] Error 1
make[2]: Leaving directory '/firmware/user'
../../../build/recurse.mk:11: recipe for target 'user' failed
make[1]: *** [user] Error 2
make[1]: Leaving directory '/firmware/modules/photon/user-part'
../build/recurse.mk:11: recipe for target 'modules/photon/user-part' failed
make: *** [modules/photon/user-part] Error 2
Does anyone know how I can fix this? is there any other library to use to receive RF 433 learning code remote controls?
I was able to make it work with arduino and RCswitch library to receive the codes and do actions accordingly but I keep getting this error on particle , I searched all over internet and I couldn’t find any solution
thank you in advance for taking a look on this topic
Frankly, the library is written pretty poorly. However, I managed to get it to compile on my machine by fixing a few return statements. As indicated in the compiler output, there are several functions that are supposed to return char* (pointer to char) but return a char instead:
lib/RCSwitch/RCSwitch.cpp:250:12: invalid conversion from ‘char’ to ‘char*’ [-fpermissive]
lib/RCSwitch/RCSwitch.cpp:323:12: invalid conversion from ‘char’ to ‘char*’ [-fpermissive]
lib/RCSwitch/RCSwitch.cpp:388:20: invalid conversion from ‘char’ to ‘char*’ [-fpermissive]
lib/RCSwitch/RCSwitch.cpp:408:20: invalid conversion from ‘char’ to ‘char*’ [-fpermissive]
By changing the return values from '\0' to NULL on lines 250, 323, 388, and 408 of RCSwitch.cpp the error is resolved:
return '\0'; // Error
return NULL; // No error
Yes, that worked
thank you very much for your help I really appreciate it
you mentioned the library is written poorly
is the any better library to just receive 433 RF signals from a remote control?
I’m not familar with any other libraries for 433MHz remotes. If the library works well enough for your project you shouldn’t bother worrying about it.
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
