Publish to Google sheet question
I am suffering a severe brain cramp. Usually when I encounter a problem with my code, I can eventually fix it once I engage a few in-reserve brain cells. This one is driving me nuts though:
I have been successfully publishing events to a Google sheet via a webhook for months. The events have been integers converted to strings like this:
Particle.publish ("Height",String(height));
I recently decided that it’d be useful to append a plus sign to the event data, so I modified the code as follows:
Particle.publish ("Height",String(height)+"+");
Now nothing shows up in the sheet for that event name.
The attached screenshot of a section of the sheet shows that the Height field was empty until I removed the “+” sign around 6 AM.
I’m sure there is a simle explanation but it escapes me. Anyone able to offer advice?
@blshaw45 it doesn’t work because “+” is considered a special character in building a string. You could use Particle.publish ("Height",String(height)+String(“+”)); or specify the “+” as a character literal like this: Particle.publish ("Height",String(height) + '+');
Personally, I avoid using Strings and use snprintf() and c-string arrays (char array), which avoids dynamic memory allocation used by String and possible heap fragmentation.
Oops; I take it back. Neither of those first two suggested solutions work. Same blank data field/cell. I’ll experiment with snprintf() next. Stay tuned.
BINGO!!
You’re the man PK! Muchas Gracias!
