I purchased a AC/DC switching power supply like this to power a Photon. When I turn the AC on the DC voltage read by the multimeter is not instantaneously 12 vdc but quickly increases from 0 vdc. Does anyone know if this is normal for power supplies? And would this be harmful to the Photon to momentarily supply it with less than 7-15 vdc (I have the photon on the shield shield) ?
I’ve separated the circuits for now with a switch so I can wait until the PSU is reading 12 vdc before powering on the Photon.
@casche, the PSU might have a soft-start feature to prevent overshoot and “shock” on initial power-up. What I am not sure about is how are you powering the Photon with a 12VDC supply?
From the 12vdc psu into the shield shield's vin/gnd According to the data sheet anywhere between 7-15vdc is fine.
I emailed particle support:
Chris,
Thanks for reaching out. Let me make sure I understand your situation:
You are using a power supply with an output that gradually drains from 12 VDC to 0 VDC over a non-trivial amount of time (~1 second). You are worried that an under-voltage condition might damage the Photon.
If this is correct you need not worry. While sustained under-voltage conditions can potentially damage a Photon 1 second is not considered sustained.
