I’ve been trying for some time to upload to my particle offline via USB. However, I am not having much luck.
I have tried two approaches, and I would really appreciate it if you could help me figure out what I’m doing wrong.
In both approaches, I try to upload the same sketch, led.ino which should just set D7 (the blue led pin) to HIGH. However, the LED doesn’t light up. (I’ve also tried setting the LED to LOW just to check if that would work.)
Here’s the program:
pinMode(D7, OUTPUT);
digitalWrite(D7, HIGH);
delay(1);
Just to make sure I’m not making a simple syntactical error, I’ve also tried the following programs from other authors:
#define PIN D7
int state = 0;
//tell the device we want to write to this pin
pinMode(PIN, OUTPUT);
//alternate the PIN between high and low
digitalWrite(PIN, (state) ? HIGH : LOW);
//invert the state
state = !state;
//wait half a second
delay(500);
and
int ledPin = D7;
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH);
delay(250);
digitalWrite(ledPin, LOW);
delay(250);
Okay, here we gothe first and most “straightforward” method:
With led.ino in the same directory I run:
particle compile photon led.ino --saveTo firmware.bin
I then get the following encouraging output (along with a new firmware.bin file):
Compiling code for photon
Including:
led.ino
downloading binary from: /v1/binaries/594c045c9033913766700b9c
saving to: firmware.bin
Memory use:
text data bss dec hex filename
5132 8 1448 6588 19bc /workspace/target/workspace.elf
Compile succeeded.
Saved firmware to: C:\Users\dexter\Documents\photon\test3\firmware.bin
Then, I run particle flash --usb firmware.bin which gives me the following output:
Found DFU device 2b04:d006
spawning dfu-util -d 2b04:d006 -a 0 -i 0 -s 0x080A0000:leave -D firmware.bin
dfu-util 0.9
ID 2b04:d006
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x080a0000, size = 5140
Download [=========================] 100% 5140 bytes
Download done.
File downloaded successfully
Invalid DFU suffix signature
Flash success!
To me, there seem to be no warning signs (except for possibly the Invalid DFU suffix signature warning). However, the LED on my photon does not light up. (Side note: I know that the LED isn’t broken, as it turns on when I enter DFU mode)
For the second approach, I followed Sparkfun’s Tutorial to the letter. That didn’t work either.
Then I tried rebuilding everything via the Local build using gcc-arm Tutorial. This didn’t work either.
Also, my firmware is up to date. I updated it with the following commands:
dfu-util -d 0x2B04:0xD006 -a 0 -s 0x8020000 -D system-part1-0.6.2-photon.bin
dfu-util -d 0x2B04:0xD006 -a 0 -s 0x8060000:leave -D system-part2-0.6.2-photon.bin
Any help would be wonderful
I feel like I’ve run out of options/leads to chase as I don’t have a single error and I’ve recompiled everything multiple times from source. If there’s anything I can clarify, please let me know
EDIT: I am running windows 10
