Hi,
I've noticed with my Boron BRN404X that I can set breakpoints with the Particle debugger in VSC I cannot clear them. That is, even if I delete the breakpoint it will trigger again on the next pass through that code. The only solution has been to reflash the device. I have noticed that the topic Breakpoints keep firing after removal has been viewed 554 times so I am guessing this is being experienced by a lot of others. Any suggestions how to remedy this witchout reflashing each time you want to change a breakpoint?
