I’m using the Particle debugger, Particle workbench with VSCode and B5som Module.
I’m able to set breakpoints and they fire as expected, but when i remove the breakpoint, the breakpoint keeps firing.
Hi @jesperborri ,
I have exactly the same problem with Boron BRN module. Very annoying. Did you find a solution to this problem?
