I have some problems using a Grove Sound Sensor (or Grove Temperature Sensor) connected to VIN, GND and A0. The sonsors are running fine with my arduino, but with a particle (connected to usb) the analogRead function returns strange readings. In the following sections you can see my code and the result.
#define GROVE_PIN A0
long now = (long) millis();
while( (!Serial.available()) && (( ((long) millis()) - now) < 5000) ) {
Particle.process();
Serial.println("started...");
pinMode(GROVE_PIN, INPUT);
void groveSound(int val) {
int sensorValue = val;
Serial.print("val: ");
Serial.println(sensorValue);
if(sensorValue > 200) {
Serial.println("on");
delay(1000);
groveSound( analogRead(GROVE_PIN) );
delay(10);
//Serial.println("");
Spark.process();
//delay(1000);
Output (there is no sound at all, Arduino has values between 10 - 20):
started...
val:92
val:75
val:57
val:57
val:61
val:74
val:77
val:71
val:86
val:88
val:106
val:124
val:129
val:152
val:164
val:180
val:222
on
val:85
val:66
val:59
val:68
val:78
val:69
val:71
val:103
val:98
val:79
val:86
val:91
val:148
val:176
val:237
on
val:195
val:207
on
val:92
val:124
val:149
val:155
val:172
val:161
val:144
val:134
val:148
val:167
val:176
val:202
on
val:166
val:156
val:161
val:120
val:92
val:73
val:117
val:155
val:155
val:160
val:207
on
val:68
val:61
val:49
val:50
val:52
val:93
val:115
val:118
val:123
val:136
val:143
val:169
val:171
val:191
val:200
val:179
val:190
val:222
on
val:207
on
val:167
val:183
val:183
val:150
val:132
val:128
val:135
val:125
val:110
val:110
val:148
val:177
val:179
val:160
val:158
val:172
val:188
val:206
on
val:124
val:117
val:101
val:77
val:76
val:77
val:64
val:61
val:92
val:119
val:109
val:113
val:123
val:142
val:172
val:210
on
val:159
val:121
val:89
val:96
val:131
val:164
val:160
val:142
val:122
val:118
val:142
val:171
val:205
on
val:78
val:66
val:80
val:95
val:99
val:74
val:70
val:115
val:157
val:155
val:142
val:144
val:152
val:133
val:140
val:184
val:239
on
val:61
val:70
val:148
val:125
val:97
val:81
val:127
val:212
on
val:145
val:113
val:109
val:130
val:167
val:151
val:163
val:191
val:194
val:170
val:158
val:125
val:140
val:167
val:194
val:198
val:184
val:182
val:193
val:202
on
val:181
val:174
val:194
val:209
on
I tried several firmware versions, but that does not fix the problem.
Any ideas?
Greetings,
Sandy
