I’ve been working on building a small robot that runs two motors, 2 rgb, leds, a speaker, and and IR receiver. I got everything tested out and it was working fine on the breadboard. I got it all soldered into a compact pcb and mounted it into a 3D printed casing.
Now after I charge my LiPo battery powering the Photon, then turn the Photon on to connect to the WiFi, all I get is the constant blinking of the Red LED. I can’t put it into safe mode (hold setup press reset) for whenever I try, it goes back into the SOS.
I’ve removed the LiPo battery and tried running it through a USB connection and still.
I can get into the DFU mode (flashing yellow) by holding setup for a while after touching the reset. Once in DFU mode I can’t do anything. My computer recognizes the device connected to COM12 in the device manager but I can’t run particle update
or flash it through the CLI.
Please help me out, I’m trying to get this to work without having to replace the Photon because it’s completely soldered inside my PCB and I need to get this to work soon. From my guess I think the SOS mode is for a firmware crash, but here is a Gif of the LED:
