I would like to keep some workbench projects in my iCloud folder.
The path for that folder is something like: /Users/sam/Library/Mobile Documents/com~apple~CloudDocs/workbench-icloud-test-feb16/
There is always whitespace between Mobile and Documents.
I know workbench does not like whitespaces in a path, but I can create a project there if I create a shortcut from my Documents folder to the iCloud folder.
However once I try to compile some code, I will always get something like:
../../../build/module.mk:224: warning: overriding commands for target `/Users/sam/Library/Mobile'
../../../build/module.mk:217: warning: ignoring old commands for target `/Users/sam/Library/Mobile'
../../../build/module.mk:224: warning: overriding commands for target `/Users/sam/.particle/toolchains/deviceOS/4.0.2/main/Documents/com~apple~CloudDocs/workbench-icloud-test-feb16/target/4.0.2/argon//Mobile'
../../../build/module.mk:217: warning: ignoring old commands for target `/Users/sam/.particle/toolchains/deviceOS/4.0.2/main/Documents/com~apple~CloudDocs/workbench-icloud-test-feb16/target/4.0.2/argon//Mobile'
../../../build/module.mk:233: warning: overriding commands for target `/Users/sam/Library/Mobile'
../../../build/module.mk:224: warning: ignoring old commands for target `/Users/sam/Library/Mobile'
../../../build/module.mk:233: warning: overriding commands for target `/Users/sam/.particle/toolchains/deviceOS/4.0.2/main/Documents/com~apple~CloudDocs/workbench-icloud-test-feb16/target/4.0.2/argon//Mobile'
../../../build/module.mk:224: warning: ignoring old commands for target `/Users/sam/.particle/toolchains/deviceOS/4.0.2/main/Documents/com~apple~CloudDocs/workbench-icloud-test-feb16/target/4.0.2/argon//Mobile'
../../../build/module.mk:257: warning: overriding commands for target `/Users/sam/Library/Mobile'
../../../build/module.mk:233: warning: ignoring old commands for target `/Users/sam/Library/Mobile'
../../../build/module.mk:262: warning: overriding commands for target `/Users/sam/Library/Mobile'
../../../build/module.mk:257: warning: ignoring old commands for target `/Users/sam/Library/Mobile'
../../../build/module.mk:278: warning: overriding commands for target `/Users/sam/Library/Mobile'
../../../build/module.mk:262: warning: ignoring old commands for target `/Users/sam/Library/Mobile'
makefile:47: warning: overriding commands for target `/Users/sam/Library/Mobile'
../../../build/module.mk:278: warning: ignoring old commands for target `/Users/sam/Library/Mobile'
makefile:47: warning: overriding commands for target `/Users/sam/.particle/toolchains/deviceOS/4.0.2/main/Documents/com~apple~CloudDocs/workbench-icloud-test-feb16/target/4.0.2/argon//Mobile'
../../../build/module.mk:233: warning: ignoring old commands for target `/Users/sam/.particle/toolchains/deviceOS/4.0.2/main/Documents/com~apple~CloudDocs/workbench-icloud-test-feb16/target/4.0.2/argon//Mobile'
make[2]: Circular /Users/sam/Library/Mobile <- /Users/sam/Library/Mobile dependency dropped.
make[2]: Circular /Users/sam/.particle/toolchains/deviceOS/4.0.2/main/Documents/com~apple~CloudDocs/workbench-icloud-test-feb16/target/4.0.2/argon//Mobile <- /Users/sam/Library/Mobile dependency dropped.
make[2]: Circular /Users/sam/.particle/toolchains/deviceOS/4.0.2/main/Documents/com~apple~CloudDocs/workbench-icloud-test-feb16/target/4.0.2/argon//Mobile <- /Users/sam/.particle/toolchains/deviceOS/4.0.2/main/Documents/com~apple~CloudDocs/workbench-icloud-test-feb16/target/4.0.2/argon//Mobile dependency dropped.
make[2]: Circular workbench-icloud-test-feb16.elf <- /Users/sam/Library/Mobile dependency dropped.
/bin/bash: /Users/sam/Library/Mobile /Users/sam/.particle/toolchains/deviceOS/4.0.2/main/Documents/com~apple~CloudDocs/workbench-icloud-test-feb16/target/4.0.2/argon//platform_user_ram.ld: No such file or directory
Creating /Users/sam/Library/Mobile /Users/sam/.particle/toolchains/deviceOS/4.0.2/main/Documents/com~apple~CloudDocs/workbench-icloud-test-feb16/target/4.0.2/argon//platform_user_ram.ld ...
build.mk:67: *** "No sources found in /Users/sam/Library/Mobile Documents/com~apple~CloudDocs/workbench-icloud-test-feb16/". Stop.
make[2]: *** [user] Error 2
make[1]: *** [modules/argon/user-part] Error 2
make: *** [compile-user] Error 2
I am pretty sure workbench is just cutting off the path where it finds that whitespace in /Mobile Documents/ and cannot find any of the dependencies because it is no longer looking in the correct place.
Is there any way to remedy this so that I can keep my workbench projects on iCloud?
