Hello,
I'd like to find out which is the maximum height for the PM-BAT module, as it's not depicted at the current documentation.
I would greatly appreciate any assistance with this.
Best,
Eng. Carlos Bracho
Hello,
Best,
Eng. Carlos Bracho
4.7 mm from the bottom of the circuit board to the top of the shield for the castellated module.
7.1mm from the bottom of the plastic strip for the pin header module. This is basically the distance from board to the top of the module if you use a bottom-mount socket like the M.2 breakout board. If you use a top mount socket of course you'd also need to add the height of that.
Thanks for sharing this information, this solves my enquiry!
Have a great day,
Eng. Carlos Bracho
