Photon2 Wi-Fi setup from Mobile App
I started using the Particle Photon2 recently and tried multiple methods as suggested in the documentation to build a app to setup the Wi-Fi credentials but the app is not building properly for me.
Also is there any readymade app already exists for this?
I tried the P1 app but it's not supporting P2.
Any help is really appreciated.
There is no pre-built mobile app for configuring the P2 and Photon 2. The older Particle mobile apps cannot be used.
The recommended method is to use setup.particle.io from a computer with the device connected by USB.
@rickkas7 What is the best practice for delivering products to end-users based on the Photon 2? In my case, each of my customer's jobsites would need to connect to the local WiFi at that site.
@rickkas7 so there is no way to configure the Wi-Fi using mobile app?
There are several options for configuring Wi-Fi for customer devices here:
https://docs.particle.io/reference/device-os/wifi-setup-options/
