Photon Wifi selector software
Hi Mr. Rickkas7, What type of plug would i need for connecting the external battery to the Photon 2 with pin headers. Sir
There is a battery connector on the Photon 2 module, a JST-PH 2-pin. It's described in detail in the battery guide.
Thanks Sir
Hi Mr. Rickkas7,
Presently I am getting the following error on the softApp page
mas-july-14-2.cpp:59:21: variable 'Header h' has initializer but incomplete type
error
mas-july-14-2.cpp:81:19: invalid use of incomplete type 'struct Writer'
This is happening on all the copies of my Particle apps
Would you give me some advice please
This is on Photon1
Thanks Sir.
Header.h is not a Particle header file, and I don't know what it is. However, if you are missing struct Writer it's probably because you are missing
#include "Particle.h"
at the top of your .cpp file.
Thank you Sir. #include "Particle.h" is already in the code at the top.
What is interesting is that I have had this App for a while with no errors then all of a sudden I am coming up with this starnag error. I have 23 Photon 1 CPUs and I have not been able to sell any of them yet. That makes me nervous
Are you sure you have selected photon or p1 as the build target? That header only exists on Photon 1 and P1, and thus only on Device OS 3.x and earlier.
Also struct Header is defined in the same place.
Thank you Sir You pointed out to my mistake so smartly
Sir I have one parameter on Photon2, TZ, it is the time zone. In case of mains power down I need to store TZ so that after the power is restored my device will work OK. I could use an external battery. Is there any other way I could save TZ parameter without the use of an external battery?
How can I store TZ in the flash ram?
On the Photon 2, use EEPROM or a file on the file system.
If you wanted the parameters to be cloud configurable, per device, use Ledger.
Thank you for your advice Sir. The following example given requires the actual value of the variable to be stored in the EEPROM.
// Write a value (2 bytes in this case) to the EEPROM address
int addr = 10;
uint16_t value = 12345; // in my case it would be -4, or -5 depending on the location of my device.
EEPROM.put(addr, value);
But I have a variable TZ ( Time Zone). this value is inputted by the user through my Web App. Is there any way around this issue?
Sir there was another question I need to ask. In the read cycle from EEPROM
// Read a value (2 bytes in this case) from EEPROM address
int addr = 10;
uint16_t value;
EEPROM.get(addr, value);
if(value == 0xFFFF) {
// EEPROM was empty -> initialize value.
value = 25;
// What is the initialize for?
I don't entirely understand your question, but when you use the EEPROM for the first time on a new device, every byte is initialized to 0xff (not 0x00), so if you read a uint16_t from it, you'll get back 0xffff as the value.
Sir I need to save TZ in the EEPROM. the example given in docs.particle is as follows
int addr = 10;
12345 is the value that is saved.
can I replace it with
uint16_t value = TZ; ?
I hope I have made myself clear
I still don't understand the question. Do you mean the Unix TZ variable? That's a string, not a number, and strings are a little tricky to save in EEPROM. However, why are you setting TZ? It's not well supported by the Time class. What are you using that uses TZ?
@kazem, if you are trying to save a "time zone" value to use with the Time.zone() DeviceOS function to set the time zone on startup then you:
  • Need to use a variable name that is not in conflict with TZ such as tzone.
  • You could declare tzone as int16_t (signed) value since it can have both positive and negative values.
  • You can store the tzone value in EEPROM using:
int addr = 10;
uint16_t tzone= -5;
EEPROM.put(addr, tzone);
You can then read the value on startup (in setup()) and set the timezone using:
EEPROM.get(addr, tzone);
Time.zone(tzone);
Of course, you need to set addr and declare tzone before doing this. These could be global variables so they can be accessed from anywhere in your code.
Thanks for you kind advice sir
FYI i am using PHOTON-2
I am using GTZ variable for time zone
GTZ is inputted by the user from my webapp which could be any float number
In the main Ioop I have Time.zone(GTZ);// This can be written in set()
Can I make the following changes in your code
storing GTZ in the EEPROM
int addr = 10;
uint16_t tzone= GTZ;
GTZ = tzone
Reading GTZ in the setup()
GTZ =tzone;
Time.zone(GTZ);
@kazem, I am not sure what you are trying to do but if GTZ is a type float then store it in EEPROM as a float (4 bytes in EEPROM) instead of a uint16_t.
Thanks fir your advice. With a bit of modifications I managed. to
read the EEPROM in the maine loop. then to avoid too many reads I added the following code
if (GTZ ==0 ) { // THis is to avoide too many reads
// Reading GTZ in the Loop()
int addr = 10;
EEPROM.get(addr, GTZ);
//GTZ =tzone;
///Time.zone(GTZ);
Serial.print("GTZ4 = "); //GTZ4 is declaired
Serial.println(GTZ);
I am sorry to have to let you know that my original file got corrupter, I was unable to bring it back.
I did the code again. This time when I input a positive number for GTZ from my webApp it is Ok.
But if GTZ is a negative number like -5, -4, or any negative number it does not accept it. GTZ is stored as 0. All the variables are declared as float. I don't understand why and I can not fix it.
When I input GTZ through my WebApp. It takes me to Line 451
line 451
parser1.getOuterValueByKey("B", B);
parser1.getOuterValueByKey("TZ", TZ);
parser1.getOuterValueByKey("RN", RN);
// GMode1 = RN;
GFLRN =1;
B = B * 2.54 ;
if (SID ==0){
GTZ =TZ;
Serial.print("valueTZ2 = ");
Serial.print("GTZ = ");
// GTZ= value8
int addr = 10;
uint16_t tzone = GTZ;
GTZ = tzone;
Serial.print("valueTZ = ");
This is what I have in the main loop()
line896
loop()
int addr = 10;
uint16_t value8;
EEPROM.get(addr, value8);
// value8 = value;
GTZ = value8;
if(GTZ == 0xFFFF) {
tzone = 25;
// Serial.print("GTZ3 = ");
// Serial.println(GTZ);
// Serial.print("value4 = ");
// Serial.println(value);
Serial.print("GTZloop = ");
 delay(3000); // temporary delay
Sir I would appreciate your help
