Hello Sir. Is there a USB base WiFi set up available for my client use?
Thy must not be able to change product name. Just incase thy have a problems with softapp. I suspect thy will in the near future.
Sir You are not answering this question FYI it is about Photon.
Now is it because the answer is no or because I should look for it in the Particle Docs?
One way or the other please let me know
Thank you Sir.
Hello Sir. Is there a USB base Wi-Fi set up available for Photon2 for my clients use?
Thy must not be able to change product name. or delete the firmware
There are a number of Wi-Fi setup options for the Photon 2, described here.
Thank you sir. It was some what difficult to find the right link for this but I finally managed. The following is the link for others to use.
Thanks again Mr. rickkas7. Yesterday I created a new app on Particle web IDE.
and also saved it. When I try to add a library like SimpleDmx and or FastLED to it ,it does not show the same app for including the library to it. Even after more than 24 hours it still does not show up on the list of files for adding the library. Would you help me please? Thanks
Hi Mr. rickkas7. After waiting more than 2 days the file showed up on the list of adding libraries. Thanks for your patience.
I am trying to drive DMX pixel LED lights with Photon 2.
I am using DmxSimple and FastLED libraries. I am using FastLED and FastLED2 libraries to make use of the Palette colors and CRGB Palettes. I am getting the following error after file Verification
lib/FastLED/led_sysdefs.h:19:10: platforms/avr/led_sysdefs_avr.h: No such file or directory. What are your suggestions.
Thanks.
PS: I am suing Particle Web IDE
FastLED is not compatible with the Photon 2 and it would not be easy to fix.
Thank you Sir. I have an App, Photon-2-dmx.ino, I am including DmxSimple and Neopixel libraries. After Compiling it ( I don't know how to compile it for Photon2 )
I am getting the following errors:
photon-2-dmx.ino:25:62: 'NEO_GRB' was not declared in this scope
photon-2-dmx.ino:25:72: 'NEO_KHZ800' was not declared in this scope
photon-2-dmx.ino:36:3: 'DmxSimple' was not declared in this scope
photon-2-dmx.ino:45:3: 'DmxSimple' was not declared in this scope.
Here is my code
#include <SimpleDmx.h>
#include <neopixel.h>
//#include "DmxSimple.h"
//#include <Adafruit_NeoPixel.h>
#define NUM_LIGHTS 10 // Number of DMX lights
#define CHANNELS_PER_LIGHT 5 // 5 channels per light (RGB + Master Brightness + Timing)
#define START_CHANNEL 1 // DMX Start channel
#define DURATION 30000 // 30 seconds for each effect
#define PIN D2 // DMX output pin (connected to RS485 transceiver)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LIGHTS, PIN, NEO_GRB + NEO_KHZ800);
// Custom function to set RGB color with brightness and timing
void setPaletteColor(int light, uint8_t r, uint8_t g, uint8_t b) {
int brightness = 128; // Set master brightness (0-255)
int timing = 100; // Set a timing value (optional for control)
// Calculate DMX start channel for this light
int startChannel = START_CHANNEL + (light * CHANNELS_PER_LIGHT);
// Set DMX channels (Red, Green, Blue, Master Brightness, Timing)
DmxSimple.write(startChannel, r); // Red channel
DmxSimple.write(startChannel + 1, g); // Green channel
DmxSimple.write(startChannel + 2, b); // Blue channel
DmxSimple.write(startChannel + 3, brightness); // Master Brightness channel
DmxSimple.write(startChannel + 4, timing); // Timing channel
Serial1.begin(250000); // Start Serial1 for DMX at 250k baud (DMX standard)
DmxSimple.usePin(TX); // Use hardware TX pin for DMX output
DmxSimple.maxChannel(START_CHANNEL + (NUM_LIGHTS * CHANNELS_PER_LIGHT) - 1); // Set max DMX channels
strip.begin();
strip.show(); // Initialize all pixels to 'off'
// Rainbow effect (red, green, blue sequentially)
for (int i = 0; i < NUM_LIGHTS; i++) {
setPaletteColor(i, 255, 0, 0); // Red
delay(2000);
setPaletteColor(i, 0, 255, 0); // Green
delay(2000);
setPaletteColor(i, 0, 0, 255); // Blue
delay(2000);
// Function to apply palette colors to all lights
void applyColorSequence() {
uint8_t r = random(0, 256);
uint8_t g = random(0, 256);
uint8_t b = random(0, 256);
setPaletteColor(i, r, g, b);
delay(DURATION); // Run for the defined duration
Hi Mr. Rickkas7, Is it possible to drive ESP32 with Particle cloud?
Hi Mr. rickkas7,
Why does it take 3 days for a new App to show up on the list of Apps in the online Particle IDE.
Thanks Sir
Sorry I ment I can not add libraries. I have to wait 3 days for it to show up.
The App has already been saved
That's not a known issue. You could try using the settings (gear) icon in the left and using the Clear Cache option. You could also try clearing your browser cache.
However you really should switch to Particle Workbench and not use the Web IDE.
Thanks for the clarifications Sir.
NeoPixel library for the photon says it is the Adafruit library. It is not called Adafruit_Neopixel library. The compiler does not recognize this line
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, DATA_PIN, NEO_GRB + NEO_KHZ800);. Would you help me on this issue please
Thanks Sir
Is this on the Photon 2? You need to specify SPI or SPI1 as the pin, instead of a pin name or number. See these instructions.
Thanks Sir. Yes Sir I am using Photon2, I tried SPI and SPI1, I have no errors this time but I am not getting any signals on SPI nor the SPI1. There are 3 pins named SPI1 on Photon 2. I checked all 3 of them
#include "Particle.h"
// Let Device OS manage the connection to the Particle Cloud
SYSTEM_MODE(AUTOMATIC);
SYSTEM_THREAD(ENABLED);
// Define pin and number of LEDs
#define PIXEL_PIN SPI1 // Pin connected to the WS2812 LED strip
#define PIXEL_COUNT 60 // Number of LEDs in your strip
#define PIXEL_TYPE WS2812B
// Create NeoPixel object
Adafruit_NeoPixel strip(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE);
// Global variables for timing and state
unsigned long previousMillis = 0; // Stores the last time LEDs were updated
unsigned long interval = 10000; // Duration for each color (10 seconds)
int currentColor = 0; // 0 = Red, 1 = Green, 2 = Blue
strip.begin(); // Initialize the LED strip
strip.show(); // Turn off all LEDs initially
// Get the current time
unsigned long currentMillis = millis();
// Check if it's time to update the color
if (currentMillis - previousMillis >= interval) {
previousMillis = currentMillis; // Update the last update time
updateColor(); // Change the LED color
// Function to update the LED color
void updateColor() {
if (currentColor == 0) {
setColor(255, 0, 0); // Red
} else if (currentColor == 1) {
setColor(0, 255, 0); // Green
} else if (currentColor == 2) {
setColor(0, 0, 255); // Blue
// Move to the next color, loop back to red after blue
currentColor = (currentColor + 1) % 3;
// Function to set all LEDs to a specific color
void setColor(uint8_t r, uint8_t g, uint8_t b) {
for (int i = 0; i < PIXEL_COUNT; i++) {
strip.setPixelColor(i, strip.Color(r, g, b));
strip.show(); // Update the LED strip
If you are using SPI1 you use D2.
However a 60 pixel strip is large and will almost certainly require an external power supply. How are you powering it? Do you have the level shifter? The Adafruit NeoPixel guide has a lot of useful information about this.
Thanks Sir. I am using Oscilloscope to check the the output signal from SPI1. and I am getting no signal. I should be getting at least 3.3 volt signal
Yes I will be using an external power supply and a level shifter once I do get a signal from SPI1
Clearing the Cache did the job Thanks a lot Sir
