I made a mistake (first day!) and overheated the step-down voltage regulator by hooking up servo directly to Vin. The photon seemed to be dead (no lights at all) until I unsoldered this regulator. Now, I can only power the board using 3V3 pin, but photon works extremely unstable with that method of power supply.
So, the question is the next: can I make a jumper at a former voltage regulator place and use the board with the ‘conventional’ power supply?
