Looks like the regulator on my Particle is faulty. When powering it with 5v on the VIN pin, it only manages to get the 3v3 up to 2,9v. Powering it with 3.3v directly on the 3v3 pin, it works as expected.
Anyone else having had problems with the on board regulator? And if so, what was the fix?
I can give it a go, but according to the schematic, both vin and usb is connected to the same pin on the regulator, with the exception of a diode between usb and the input.
When powering it directly on the 3v3 pin, both my Extech multimeter and bench supply reports it drawing around 90mA. It does behave normally when powered directly on the 3v3 pin, and running and responding to the tinker app just fine. When powering it on VIN or USB, all leds turns on dimmed, and nothing else happens.
