Photon unable to log into cloud after working for 1 year
Hi all,
I was running Photon application for about 1 year. On Apr 3rd Photon stopped working. FW version was 0.5.0 and I tried to set up WIFI again. It did not work. It is possible to get into WIFI, get IP and I am able to ping it, but instead of logging into cloud there is one short red blink on LED and the login procedure starts from the begining.
I have tried particle keys doctor on 0.5.0 and it worked fine. No change:-(
I have updated particle CLI on my PC and updated FW to 0.6.1:
system firmware version: 0.6.1
Nothing has changed. I am still not able to login to cloud. I have repeated particle keys doctor and it did not help. The photon is visible via serial:
D:\Particle>particle serial list
Found 1 device connected via serial:
COM6 - Photon
but not accessible (probably because of failed cloud login procedure)
D:\Particle>particle serial identify
! serial: Serial timed out
I can get version and info via putty when in config mode.
Any idea what could be the problem? How to further troubleshoot?
thx a lot
mirek
Have you tried Safe Mode?
I tried, but it seems I can not put Photon to Safe mode. When I saw magenta I have released setup button and it started again the cloud login procedure with red blink at the end.
Could you shoot a video of the process? Also, if you could give particle update and particle flash --usb tinker, that might help.
Your keys might have gone out of sync
Try this in DFU Mode
particle keys server
particle keys doctor <yourDeviceID>
This sounds like an issue commonly refered to as red burst
https://community.particle.io/search?q=burst
Hi ScruffR,
thx a lot. It is back online. Your 2 magic commands worked well.
I apologize I did not find it in the forum history.
Does this happen very often?
Is there a way to also avoid this?
That is actually a question that does come up more often recently, but I can’t really answer that.
Maybe @jeiden from Particle might have some background on that.
I would defer to @bryce on this one
@bryce - any update on this one?
@Cameron I know @BDub has been looking into the causes of a device losing its keys.
Do you guys sit next to each other - maybe before we bounce onto the next person we can double check we have the right one? :slight_smile:
@BDub - can you help on this one please? :slight_smile:
