I suppose you have replaced dev_id with your actual device ID.
You may also want to shoot this after particle keys doctor <yourDeviceID>
particle keys server
And make sure your CLI is 1.16.0 (or newer)
Whoah!
That did it!
Device is connected, back in my dashboard as well and uploading is going great again.
Many thanks
Hey @omarojo – your most recent post is a bit different than the original topic, “Photon setup flashing cyan with a “quick red burst” (now orange burst)”, so I am going to move it into a new post with the title, “Flashing Cyan”.
Hi guys, having a nightmare here with a soldered in photon flashing cyan/red…
Tried everything in this article (with an updated CLI):
- particle keys server cloud_public.der
- particle keys new
- photon particle keys load photon.der
- particle keys send 430032000F51353338363333 photon.pub.pem
- particle keys doctor 430032000F51353338363333
- particle update
- particle flash --usb tinker
Still no luck
I can see the system firmware is 0.5.3 and when I try the command:
- particle device add 430032000F51353338363333
I get: Failed to claim device, server said: [object Object]
Can someone help? @BDub can you try provisioning a new key like you did before?
Can you post the output of these commands?
(in Listening Mode blinking blue)
particle identify
(in DFU Mode blinking yellow)
And also a video of the blinking LED to see what exactly we are up against?
Having a look at the output of particle update wouldn’t hurt either.
Thanks for your quick replies.
@ScruffR ;
Response to particle identify
Your device id is 430032000f51353338363333
Your system firmware version is 0.5.3
Response to particle keys server
Found DFU device 2b04:d006
checking file C:\Users\dcsim\AppData\Roaming\npm\node_modules\particle-cli\keys\rsa.pub.der
spawning dfu-util -d 2b04:d006 -a 1 -i 0 -s 2082 -D C:\Users\dcsim\AppData\Roaming\npm\node_modules\particle-cli\keys\rsa.pub.der
dfu-util 0.8
ID 2b04:d006
Claiming USB DFU Interface...
Setting Alternate Setting #1 ...
dfuIDLE, continuing
DfuSe interface name: "DCT Flash "
Downloading to address = 0x00000822, size = 512
Download [=========================] 100% 512 bytes
Download done.
File downloaded successfully
Invalid DFU suffix signature
Okay! New keys in place, your device will not restart.
Response to particle keys doctor 430032000F51353338363333
New Key Created!
This file already exists, please specify a different file, or use the --force flag.
Continuing...
checking file 430032000F51353338363333_rsa_new.der
spawning dfu-util -d 2b04:d006 -a 1 -i 0 -s 34:leave -D 430032000F51353338363333_rsa_new.der
dfu-util 0.8
ID 2b04:d006
dfuIDLE, continuing
Downloading to address = 0x00000022, size = 608
Download [=========================] 100% 608 bytes
Download done.
Saved!
attempting to add a new public key for device 430032000F51353338363333
submitting public key succeeded!
Okay! New keys in place, your device should restart.
@Moors7, response to particle update
> Your device is ready for a system update.
> This process should take about 30 seconds. Here goes!
! System firmware update successfully completed!
> Your device should now restart automatically.
> You may need to re-flash your application to the device.
Here is the video of the blinking LED (sorry for poor quality, I may have over-compressed it): https://drive.google.com/open?id=0B318xmkMW6WJd2pWaXF6Wk9Ta28
I see you’ve got the Photon soldered to a custom PCB, so chances are that the external circuitry does overstress the USB power supply on connection attempt causing the key hanshake to fail or your PCB design does cause degraded antenna performance.
Try a different cable (these old Spark USB cables weren’t too good), a 2A minimum USB power supply and possibly a uFL antenna (needs to be selected in code too).
How does your keepout area around the chip antenna look?
There was another thread by @UMD having troubles with a mounted Photon and reception a while back
Photon SoftAP mode - mobile cannot obtain address
and also this
Photon SMD Antena, keepout zones, and ground loops
The boards have DC jacks fitted and an LDO regulator capable of supplying > 2A, but connecting to the plug does not help.
Here is the keepout area:
I don’t think it is a hardware problem since I’ve got 5 others working fine! The only difference with this one is the way I set it up; instead of using the Particle app, I tried the CLI to set the WiFi credentials using particle setup wifi. It connected and was breathing cyan but would not allow me to add the ID to my account. Thinking there may be a problem with the keys, I generated fresh ones, which is when the problems started…
Maybe pinging @BDub again might help.
You can also open a support ticket with a reference to this thread.
So the update went through, but you’re still ‘stuck’ on 0.5.3, which is not the latest version. Try updating your CLI and give it another shot?
Updated CLI and photon again, it’s version has changed to 0.60 but the red light problem still persists (even after another go at key doctor).
@Moors7 @ScruffR, so I opened a support ticket and came to a solution - it turns out the IDs are case sensitive! In other words, if there is a letter in there, it must be LOWERCASE! I just had to run the key doctor with lowercase “f”.
Sometimes the solution is so simple…
Thanks for your help though guys.
Darn, this has bitten again!
This is an open issue for CLI which should have been addressed a year ago.
Thanks Scruff this worked great - particle keys doctor 123456789ID particle keys server
Nothing else had worked at all
Cheers
This fixed the issue!! (out of all the others – like generating new keys, uploading them, etc). Thank you!!
Hey, so im going to bring this topic back to life because i havnt been able to fix it for almost a week now.
I have a classroom set of sparkfun photon redboards, with the majority running the 0.5.3 firmware. Im trying to get them all up and running on the latest firmware which is 0.6.2, but when i update them, they devices turn into bricks!
i get the cyan flashing with 3 red flashes. I have tried everything listed in this thread to get it working:
particle keys doctor deviceid
particle keys server device.der
particle keys new
particle keys load device.der
particle keys send deviceid device.pub.pem
and every other variation all all sorts of orders
i have tried reverting back to old firmware such as 0.5.3, but each time i try to update the key on the server using ‘send’ or ‘doctor’ i get a
Error sending public key to server: Permission Denied
eg: particle keys doctor deviceid
C:\Users\ioannidisa>particle keys doctor 230025000e47343337373737
Found DFU device 2b04:d008
New Key Created!
Continuing...
spawning dfu-util -d 2b04:d008 -a 1 -i 0 -s 34:leave -D 230025000e47343337373737_rsa_new.der
dfu-util 0.8
ID 2b04:d008
dfuIDLE, continuing
Downloading to address = 0x00000022, size = 609
Download [=========================] 100% 609 bytes
Download done.
Saved!
attempting to add a new public key for device 230025000e47343337373737
Make sure your device is in DFU mode (blinking yellow), and that your computer is online.
Error - undefined
I cant finish the particle setup to claim the device as when it goes to connect to the cloud, the bad key still blocks it
i need some new ideas!!!
Try opening the command prompt as an administrator, and make sure the device is in the proper mode. Also, running Particle update and Particle flash --usb tinker, shouldn’t hurt
I should of mentioned ive tried a particle update and particle flash --usb tinker they dont change anything as the device still wont connect to the server
i have also tried manually flashing different firmware
