You need to take the device out of that anti static sponge!
These spunges are slightly conductive and can cause some “short circuits” conditions that definetly interfere and possibly even damage your device.
Does the RGB pattern still look the same as in your video?
I haven’t a lot of experience with RedBear Duo but you can file a support ticket at support.particle.io
Meanwhile can you share another video.
With original Particle devices you could send the device into DFU Mode from Listening Mode via a setting a magic baudrate (14400) from the host - not sure if this is also possible on the Duo.
Apologies but this will be the least comprehensive resolution steps ever.
Managed to get the things to reset and wipe wifi credentials by holding and the rest and setup buttons until blue light came back.
In this state I checked thje firmware and both devices were on 0.3.1, whereas the latest firmware is 0.3.3
On to DFU mode…
I had to unplug the device from my laptop USB. Using a power bank I had to hold both buttons down with a pair of wooden chopsticks then plug in the power bank.
Releasing the reset button but not setup I found that I was able to get it into DFU mode… Finally…
Once achieved on the power bank I switched back to the usb ports on my laptop and repeated the step 4…
I checked the connection through the serial montior in the arduino IDE and used the IDE environment to run the burner which updated the firmware.
Now they both finally work and are connected to the Particle Cloud…
Going to go lie down for a bit ready for round 2 tomorrow
Hey! I have been trying to troubleshoot this problem as well on my new Argon Board. I had it successfully connected but when I flash code to it, then I enter the fast cyan blinking with a red blink loop.
I have been going through this thread and tried several things, however, I always get stuck at this part:
C:\Users\Owner>particle keys server cloud_public.der
Please specify a server key in DER format.
And I am not sure what to do from here, I am hoping that once I do this part right, the Argon will be back and running correctly!
