Hello
suddenly my photon is unresponsive, steady blue light next to D7
Photon RGB LED does not turn on at all even in Safe mode
Any help?
thanks in advance
Hello
Any help?
thanks in advance
That is a problem that’s not yet fully understood, but mostly happens after some power issues
See all these threads
https://community.particle.io/search?q=dim%20d7
@Lagartus do you have another Photon module?
yes I do
You might take a look at this post and give it a shot to recover the Photon:
IVE VERIFIED CONNECTIONS AND AT THE
TERMINAL BOX
SWD Fault error
Please double check the wiring, then try again."
IM USING A 10K RESISTOR 1/4
THE PROGRAMMER RGB CHANGES TO MULTICOLOR
AND THE TARGET BLUE LIGHT IS MORE INTENSE
ANY HELP?
Just a netiquett reminder: All capital letters is considered as shouting in posts, please refrain from doing so
