I recently was running code and it caused my Photon to go into SOS mode(think I overloaded the OLED when trying to get it to display Motion Detected/No Motion from the PIR Sensor). I went through the process of putting it into Safe Mode and then attempted to reset it via the Particle CLI Device Doctor. I got a message basically saying my device couldn’t be found. Switched to DFU Mode, same problem. I went back and tried using Zadig, but when I list all devices, there’s nothing there:
So I check Device Manager and there’s nothing there either (I know it should come up as Other Devices because I had to reconfigure my Photon in a similar manner):
I went through the process of resetting up the Photon via the setup.particle.io and and I got it breathing cyan, however none of my previous code (outside of the basic LED practice) works.
So now I’m back to trying the Zadig/Particle CLI route but the device is still not coming up (although it is recognized in Tinker and IDE as online with no issues outside of DFU Mode).
