Photon no status LED, but has voltage
Hello,
I have an original Photon that I'm trying to get working (while waiting for my Particle Programmer to upgrade the firmware of my Xenons) and the Photon is not working.
Testing it on a Shield Shield board (led lights up on there) and standalone, I do not get an LED on the device. Trying to perform a factory reset does nothing. Plugging it into a PC, I do not see it in device manager.
The buttons on the device do not seem to affect anything.
I can read 3.2-3.3V on the 3V3 pin. I read ~4.9V on the 5V pin. The D7 pin has maybe 40-50mA of current.
I've also emailed support but the automated message said to reach out here.
Any suggestions as to what I can do to get my device back working?
This post sounds similar (Bricked Photon? No status LED, only blue D7), but I do not have my programmer yet (shipping snafu and had to reorder) to test the board.
Richard
@Sulli, can the Photon go into DFU or Safe modes using the Setup and Reset butttons?
@peekay123, unfortunately it cannot.
With the board disconnected, holding down Setup while plugging into a USB port does nothing (LED flashes nor showing up as a device in device manager). Similarly, holding both buttons down and releasing Reset has the same outcome described above.
Hey, for completion here are the docs on how to set the device in safe mode and DFU modes:
To put your device in Safe Mode (click for docs):
  1. Hold down BOTH buttons
  2. Release only the RESET button, while holding down the SETUP button.
  3. Wait for the LED to start blinking magenta
  4. Release the SETUP button
To enter DFU Mode (click for docs):
  3. Wait for the LED to start flashing yellow (it will flash magenta first)
@Sulli I would also take the photon off the board to test, ideally on a protoboard if you have one.
@gusgonnet, those are the procedures that I followed and the unit does not go to safe or DFU mode.
@peekay123, I have tried while plugged into the shield shield, standalone on a desk, and plugged into a breadboard. Still does not show up in Windows/go into DFU or safe mode.
I recently bought a programmer shield, but am waiting on my jtag cables and programmer to arrive.
