start with yellow blinking
particle update -v
Your device is ready for a system update.
This process should take about 30 seconds. Here it goes!
▌ Updating system firmware on the device...dfu-util 0.9
ID 2b04:d006
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x08020000, size = 262016
Downloadng syste[=========================] 100% 262016 bytes
Download done.
File downloaded successfully
▄ Updating system firmware on the device...dfu-util 0.9
ID 2b04:d006
dfuIDLE, continuing
Downloading to address = 0x08060000, size = 255264
Downloadng syste[=========================] 100% 255264 bytes
Download done.
▄ Updating system firmware on the device...dfu-util: Error during download get_status
! An error occurred while attempting to update the system firmware of your device:
dfu-util:
Please visit our community forums for help with this error:
https://community.particle.io/
Cannot read property 'code' of undefined
TypeError: Cannot read property 'code' of undefined
at dfuError (/usr/lib/node_modules/particle-cli/dist/cmd/update.js:91:17)
at dfu.findCompatibleDFU.then.catch.err (/usr/lib/node_modules/particle-cli/dist/cmd/update.js:22:11)
at tryCatchReject (/usr/lib/node_modules/particle-cli/node_modules/when/lib/makePromise.js:845:30)
at runContinuation1 (/usr/lib/node_modules/particle-cli/node_modules/when/lib/makePromise.js:804:4)
at Rejected.when (/usr/lib/node_modules/particle-cli/node_modules/when/lib/makePromise.js:625:4)
at Pending.run (/usr/lib/node_modules/particle-cli/node_modules/when/lib/makePromise.js:483:13)
at Scheduler._drain (/usr/lib/node_modules/particle-cli/node_modules/when/lib/Scheduler.js:62:19)
at Scheduler.drain (/usr/lib/node_modules/particle-cli/node_modules/when/lib/Scheduler.js:27:9)
at process._tickCallback (internal/process/next_tick.js:176:11) [ 'TypeError: Cannot read property 'code' of undefined',
' at dfuError (/usr/lib/node_modules/particle-cli/dist/cmd/update.js:91:17)',
' at dfu.findCompatibleDFU.then.catch.err (/usr/lib/node_modules/particle-cli/dist/cmd/update.js:22:11)',
' at tryCatchReject (/usr/lib/node_modules/particle-cli/node_modules/when/lib/makePromise.js:845:30)',
' at runContinuation1 (/usr/lib/node_modules/particle-cli/node_modules/when/lib/makePromise.js:804:4)',
' at Rejected.when (/usr/lib/node_modules/particle-cli/node_modules/when/lib/makePromise.js:625:4)',
' at Pending.run (/usr/lib/node_modules/particle-cli/node_modules/when/lib/makePromise.js:483:13)',
' at Scheduler._drain (/usr/lib/node_modules/particle-cli/node_modules/when/lib/Scheduler.js:62:19)',
' at Scheduler.drain (/usr/lib/node_modules/particle-cli/node_modules/when/lib/Scheduler.js:27:9)',
' at process._tickCallback (internal/process/next_tick.js:176:11)' ]
now: cyan blinking with red
