Photon 5.2 - Blinking Cyan - not found in DFU mode [SOLVED]
I have a photon that is blinking cyan and every 10 or 15 seconds I see the LED cycle through the other colors and then it goes right back to blinking cyan. The last thing I did (and it went through without any errors) was run the particle_firmware_manager-v0.5.2b-windows updater on it.
Also when I put into DFU mode it can not be found by particle update or the DFU util.
Any ideas what might be wrong?
Cloud keys were either missing or corrupt. I did the following to resolve the issue.
Installed DFU drivers
particle keys new
particle update
particle serial wifi
Thanks for sharing your answer! Glad you were able to get it working again!
