I had recently bought the particle photon, based on the documentation I plugged it started blinking, I had installed the Particle photon app on android and once I logged into the app and select add photon, it shows there are no photon devices found, I am I missing something.
Update:
When I tried connecting using USB with nodejs I received below message. [particle setup]
No nearby Photons detected. Try the particle.js help command for more inform
