Thanks for getting back to me. Here's the log. (more comments by me way at the bottom after the tinker load attempt)
C:\Users\k>particle update -v
Your device is ready for a system update.
This process should take about 30 seconds. Here it goes!
ā Updating system firmware on the device...dfu-util 0.8
ID 2b04:d006
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x080c0000, size = 15336
Downloadng syste[=========================] 100% 15336 bytes
Download done.
File downloaded successfully
Invalid DFU suffix signature
ā Updating system firmware on the device...Opening DFU capable USB device...
ID 2b04:d006
Setting Alternate Setting #1 ...
dfuIDLE, continuing
DfuSe interface name: "DCT Flash "
Downloading to address = 0x000006d9, size = 1
Download [ ] 0% 0 bytesFile too short for DFU suffix
Error during download get_status
! An error occurred while attempting to update the system firmware of your device:
Please visit our community forums for help with this error:
https://community.particle.io/
Cannot read property 'code' of undefined
TypeError: Cannot read property 'code' of undefined
at dfuError (C:\Users\k\AppData\Local\particle\node_modules\particle-cli\dist\cmd\update.js:120:18)
at dfu.findCompatibleDFU.then.catch.err (C:\Users\k\AppData\Local\particle\node_modules\particle-cli\dist\cmd\update.js:31:14)
at
at runMicrotasksCallback (internal/process/next_tick.js:122:5)
at _combinedTickCallback (internal/process/next_tick.js:132:7)
at process._tickCallback (internal/process/next_tick.js:181:9)
C:\Users\k>
C:\Users\k>particle flash --usb tinker -v
dfu-util 0.8
ID 2b04:d006
Determining device status: state = dfuDNLOAD-IDLE, status = 0
aborting previous incomplete transfer
dfuIDLE, continuing
Downloading to address = 0x080a0000, size = 5324
Download [=========================] 100% 5324 bytes
Download done.
Flash success!
The status LED light went dark (D4 LED constantly on) after tinker load.
I can see very tiny blinks of red on the status LED, but mostly dark.
After about 16 seconds, it starts blinking yellow again.
