Can't Flash Old Photon
I have an older photon that hasn’t been used in a while. I’m not sure how old it is but it’s more than a year, probably closer to two. I don’t know what version of the device FW is installed.
I was able to get it connected to the cloud using the particle app, and it shows up in Particle Console, and I can ping it. Console lists system firmware as unknown. When I use “particle list” on the CLI (v1.29.0), it’s showing as offline. The device is in safe mode. I changed the account it was registered to during the setup process.
Things I have tried:
  • Flashing Tinker via cloud on CLI --> Flash device failed. Timed Out.
  • Flashing Tinker via DFU on CLI --> TYPICAL DFU SUFFIX MESSAGE “Error during download get_status”
  • Particle Device Doctor on CLI --> Same error as flashing tinker via DFU
  • Flashing Tinker via Serial on CLI --> “Flash success”, however device is still breathing magenta
  • Flashing a simple Blink app via Particle Build --> “Flash unsuccessful” using multiple versions of target FW.
  • Particle Update on CLI --> same as other DFU errors plus “Cannot read property ‘code’ of undefined”
Any suggestions for further things to try before I pitch this thing?
Could you try ‘particle doctor’ in the CLI?
Was this device ever set to be part of a PRODUCT?
@Moors7 I’ve tried device doctor with no luck
@ScruffR There’s a good chance this device was part of a product on the previous account
Update:
Particle Identify via the CLI -->
Your device id is XXXXXXXXX
Your system firmware version is 0.7.0
Partially Solved:
I did a manual DFU-UTIL update with version 0.4.7 thanks to this post by @ScruffR. However, when I try to update to version 0.7.0 using either “Particle Update” on CLI or manual DFU-UTIL update, I am stuck in safe mode again.
Interestingly, Particle Console says the System Firmware is 0.4.7 but Particle Identify says it’s 0.7.0.
Are you able to get into listening mode (blinking dark blue) by holding down SETUP? If so, try:
particle serial inspect
That will show exactly what modules are installed on the device. I suspect your boot loader is too old and needs to be manually upgraded.
Here’s what I get from Particle Serial Inspect
Platform: 6 - Photon
Modules
  Bootloader module #0 - version 4, main location, 16384 bytes max size
    Integrity: PASS
    Address Range: PASS
    Platform: PASS
    Dependencies: PASS
  System module #1 - version 207, main location, 262144 bytes max size
    Integrity: PASS
    Address Range: PASS
    Platform: PASS
    Dependencies: PASS
  System module #2 - version 207, main location, 262144 bytes max size
    Integrity: PASS
    Address Range: PASS
    Platform: PASS
    Dependencies: FAIL
      Bootloader module #0 - version 101
  User module #1 - version 2, main location, 131072 bytes max size
    UUID: XXXXXXXXXX
    Integrity: PASS
    Address Range: PASS
    Platform: PASS
    Dependencies: PASS
      System module #2 - version 1
  User module #1 - version 2, factory location, 131072 bytes max size
    UUID: XXXXXXXXX
    Integrity: PASS
    Address Range: PASS
    Platform: PASS
    Dependencies: PASS
Yes, that’s the problem. Download the bootloader for Photon here:
Then with the Photon in listening mode (blinking dark blue):
particle flash --serial bootloader-0.7.0-photon.bin
Note that the boot loader can only be flashed in --serial mode, not in --usb (DFU blinking yellow) mode.
SOLVED:
Awesome! that worked. thanks for the help @rickkas7
Amazing! this had me stumped for hours!!! :slight_smile:
Oh my god, thank you!! I had been stuck on this for days, and had almost given up until I tried this and it all worked. Thank you!!!
For anyone else reading, if you have a super old photon that you never used up until now, you will most likely run into this problem due to super outdated firmware. Need to manually update the firmware.
SIMILAR ISSUE - BUT THAT FIX DID NOT WORK…
I had an old photon still in the box.
The photon registered fine
and connected to my WIFI and was Online and
Cyan-Breathing/Cnected to the Internet
I could see it on web and cli.
I could identify flash the led.
BUT could not flash any code (flash failed including tinker).
In the web interface it does not dispaly an “On Device Version”.
I can get to Listening Mode and DFU Mode.
I have tried RESET and SAFE MODE.
I Connected to CLI via USB serial with photon in listening mode…
particle serial identify
Your device id is 2a002a000747343232363230
Unable to determine system firmware version
d:\Users\mg\Downloads>particle serial inspect
Could not get inspect device:
Unexpected token m in JSON at position 0
I tried loading several bootloaders in Listening Mode:
sending file: bootloader-0.7.0-photon.bin
Error writing firmware: Transfer cancelled
particle flash --serial bootloader-0.7.0-RC.1-photon.bin
sending file: bootloader-0.7.0-RC.1-photon.bin
particle flash --serial bootloader-0.6.2-photon.bin
sending file: bootloader-0.6.2-photon.bin
In DFU mode I tried flashing tinker
Also tried this from the iOS App:
Particle flash --usb tinker
Error writing firmware: Invalid DFU suffix signature
Not sure what else to try.
If you haven’t already…
Update your CLI.
In DFU mode:
  • Particle update
  • Particle flash --usb tinker
Try Particle identify in listening mode afterwards, it should then list your deviceOS correctly.
See if that does anything?
to add to @Moors7
particle update-cli
from your PC/Mac command line
I guess after you did do as previous posters suggested it won't be relevant anymore, but I guess your device OS was predating the introduction of version display via particle identify and particle serial inspect.
However, in Listening Mode connecting via a serial terminal (not particle serial monitor) you can send the letter v to get the installed version.
With your particle flash ... commands it may be helpful to add the -v (verbose) switch to see some more info.
This is an old, ignorable message.
THANKS!
I had already updated my CLI and drivers...
The particle update got an error...but seemed to fix my problem anyway:
In DFU mode:
particle update
! An error occurred while attempting to update the system firmware of your device:
Error: VError: Error writing firmware: Invalid DFU suffix signature
Please visit our community forums for help with this error:
https://community.particle.io/
Cannot read property 'code' of undefined
I was then able to identify and flash the new bootloader then I could flash my software.
particle identify
Your system firmware version is 1.4.4
Flash success!
THANKS AGAIN!
