Hi, recently bought a photon and loving it, although I am currently experiencing an issue.
After un-claiming the decive, claiming it again and associating it with a different network, it would breath cyan for a couple of seconds, then flash green (not connected to cloud). If I go on the App it appears as offline. If I press on the device, the device starts flashing quickly (Wi-Fi Network Reset mode), breaths cyan for a bit, then starts flashing green again. Tried flashing the device from app, but it failed. same from web interface.
Can you put your device into Safe Mode and flash a very simple app - like blink an LED?
