I received my Photon today, WOOHOO
When I plugged it into my computer, blinking blue. Great !!
Next, Iāve entered my wifi credentials, and then blinking green⦠again⦠and again⦠and againā¦
I installed particle-cli but the device is not detectedā¦
I did nothing else, because I donāt now what to do What can I do to get it working ??
Sorry, Iām french and I have a bad english, but thanks in advance
EDIT: I find how to reset it, now it is blinking blue, yeah
But when I enter my wifi credentials, blinking green 2 seconds and back to blue⦠Why ??
That usually happens to me when I didnāt enter the WiFi credentials correctly. Make sure youāre entering them correctly (I know, duh) and the other thing you might watch out for is if you enabled something like MAC filtering on your router.
Tinker is the factory firmware that's on your Photon. It'll allow you to do all basic pin functionalities easily. Once you've programmed your Photon with your own code (which hasn't got the specific Tinker code incorporated), you won't be able to request those functions from the app anymore. If you do a factory reset, Tinker will be restored. You can also reflash it from the Web IDE like any other code.
