[Photon] Android Particle app crash when loading wifi list (io.particle.android.app E/AndroidRuntime: FATAL EXCEPTION: ModernAsyncTask)
The Android Particle app has no issue detecting the Photon but when it try to load the wifi list, it will crash. Looking at the log, there seems to be a bug related to the Particle app. I have tried this app using Android 4.4.4, 6.0.1 and N Preview 3 - none worked. Here’s the stack trace.
05-27 14:53:13.730 27616-27663/io.particle.android.app E/AndroidRuntime: FATAL EXCEPTION: ModernAsyncTask #2
        Process: io.particle.android.app, PID: 27616
        java.lang.RuntimeException: An error occurred while executing doInBackground()
        at android.support.v4.content.ModernAsyncTask$3.done(ModernAsyncTask.java:142)
        at java.util.concurrent.FutureTask.finishCompletion(FutureTask.java:355)
        at java.util.concurrent.FutureTask.setException(FutureTask.java:222)
        at java.util.concurrent.FutureTask.run(FutureTask.java:242)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587)
        at java.lang.Thread.run(Thread.java:841)
        Caused by: com.google.gson.JsonSyntaxException: com.google.gson.stream.MalformedJsonException: Unterminated object at line 2 column 906 path $.scans[13].ssid
        at com.google.gson.Gson.fromJson(Gson.java:829)
        at com.google.gson.Gson.fromJson(Gson.java:779)
        at com.google.gson.Gson.fromJson(Gson.java:728)
        at com.google.gson.Gson.fromJson(Gson.java:700)
        at io.particle.android.sdk.devicesetup.commands.CommandClient.readResponse(CommandClient.java:129)
        at io.particle.android.sdk.devicesetup.commands.CommandClient.sendAndMaybeReceive(CommandClient.java:83)
        at io.particle.android.sdk.devicesetup.commands.CommandClient.sendCommandAndReturnResponse(CommandClient.java:57)
        at io.particle.android.sdk.devicesetup.loaders.ScanApCommandLoader.loadInBackground(ScanApCommandLoader.java:65)
        at io.particle.android.sdk.devicesetup.loaders.ScanApCommandLoader.loadInBackground(ScanApCommandLoader.java:26)
        at android.support.v4.content.AsyncTaskLoader.onLoadInBackground(AsyncTaskLoader.java:296)
        at android.support.v4.content.AsyncTaskLoader$LoadTask.doInBackground(AsyncTaskLoader.java:54)
        at android.support.v4.content.AsyncTaskLoader$LoadTask.doInBackground(AsyncTaskLoader.java:42)
        at android.support.v4.content.ModernAsyncTask$2.call(ModernAsyncTask.java:128)
        at java.util.concurrent.FutureTask.run(FutureTask.java:237)
        Caused by: com.google.gson.stream.MalformedJsonException: Unterminated object at line 2 column 906 path $.scans[13].ssid
        at com.google.gson.stream.JsonReader.syntaxError(JsonReader.java:1573)
        at com.google.gson.stream.JsonReader.doPeek(JsonReader.java:495)
        at com.google.gson.stream.JsonReader.hasNext(JsonReader.java:418)
        at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:211)
        at com.google.gson.internal.bind.TypeAdapterRuntimeTypeWrapper.read(TypeAdapterRuntimeTypeWrapper.java:40)
        at com.google.gson.internal.bind.ArrayTypeAdapter.read(ArrayTypeAdapter.java:72)
        at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$1.read(ReflectiveTypeAdapterFactory.java:117)
        at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:217)
        at com.google.gson.Gson.fromJson(Gson.java:814)
Looks like we might be getting back bad wifi scan data from the device. Is this still happening?
