Does anyone know of library or instructable that has a walk through of using the RGB Matrix library with a 32x32 RGB LED display to play back animated GIFs?
Thanks, Ande
Thanks, Ande
Have you had a look at these already
RGB Pixel Clock Kit (Maker Faire 2016)
Word Clock kit (Maker Faire 2016)
Maker Faire RGBPongClock
AFAIK in the linked GitHub repo is a demo.
But @peekay123 knows best
thanks, yes Iāve been running sample code from this set. itās great - but Iām struggling to find the GIF one - maybe Iām just being dumb
In that GitHub repo I linked above you can find this file
thank you!
Iāll give this a go
Thanks both. Is there any way of adding all the files from the Animated GIF example in one go - rather than appending individually in the IDE?
@fablab, not sure what you mean. The GIF animator will read and display all valid .gif files in the ā/gifsā directory on the SD card.
in terms of flashing the firmware into the Photon - is there a simple way to take all the .cpp and .h files into the IDE with a single import. Currently Iām adding file by file
@fablab, unfortunately, not right now. The upcoming updates to the IDE and libraries will make this a lot simpler. In the meantime, I strongly recommend using Particle CLI for compiling and flashing. It allows you to compile files in a local directory using Particle cloud compilers.
ah! thanks goes hunting for CLI tutorials
@peekay123 Iām seeing this error when I compile the libraries and files from within Particle IDE. Any thoughts, suggestions?
In file included from iostream.cpp:23:0:
istream.h:32:8: error: āistreamā does not name a type
inline istream& ws(istream& is) {
istream.h:82:8: error: āistreamā does not name a type
inline istream &operator>>(istream &obj, const setfill &arg) {
istream.h:112:8: error: āistreamā does not name a type
inline istream &operator>>(istream &is, const setprecision &arg) {
@fablab, sorry for the delay. I suggest that you use Particle CLI to compile the code with all the files being in one directory. From the errors, it sounds like a file is either missing or there was a cut and paste issue when copying files to the IDE.
got it working. itās very cool!
now to design a heap of funky GIFs
thank you
@peekay123 sorry random question here, Iām trying to incorporate Blynk into the RGB animated GIF demo you created - Iām assuming this would just as simpe as adding the relevant libraries and the Blynk code into the AnimatedGIFs.cpp file? Or am I missing something.
Any pointers would be very much appreciated please.
Thanks, Ande
@fablab, youāre on the right track! The RGBMatrixPanel interrupts can be heavy so it will be interesting to see how Blynk works. Give it a shot and let me know how it goes.
Hey, is that possible to do that with a 22x22 led matrix ?
I only have 500 RGB led
Henri
The RGB panels have very specific control circuitry built-in for which the mentioned library is tailored.
So while you may be able to find a way to control your 22x22 matrix, this library will not work for that.
However, with 500 individual LEDs youāll have a job controlling them without a dedicated control circuit and lots of soldering
