Photon 2, I cannot connect to Wifi. It is 2.4 GHz. I have tired 3 times but refuses. This is a home network from a Ubiquity access point.
I would attach the log file but it is a forbidden format. .txt go figure.
The blue (D7 Power LED) is steady. The center green LED is rapidly flashing. Please advise. I do not have a 5 GHz network with the same SSID.
You can just copy and paste the log contents into a reply to this post.
Device ID: 0a10aced202194944a0451a8
0000001496 [ncp.rltk.client] INFO: rltkOff
0000001540 [ncp.rltk.client] INFO: rltkOff done
0000001178 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000004011 [app] INFO: Auto-connect disabled
0000004625 [app] INFO: doing wifiScan
0000004667 [app] INFO: Doing Wi-fi scan
0000008754 [app] INFO: wiFiScan resultCount=4
0000110558 [app] INFO: setting credentials
0000110794 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000110872 [net.ifapi] INFO: Netif wl3 state UP
0000110921 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000110997 [ncp.rltk.client] INFO: Try to connect to ssid: NSA_Long
0000111066 [net.lwip_rltk] INFO: is_promisc_enabled
0000111119 [net.lwip_rltk] INFO: get_eap_phase
0000115373 [ncp.rltk.client] INFO: disconnected
0000115922 [ncp.rltk.client] INFO: Try to connect to ssid: NSA_Long
0000115991 [net.lwip_rltk] INFO: is_promisc_enabled
0000116044 [net.lwip_rltk] INFO: get_eap_phase
0000120299 [ncp.rltk.client] INFO: disconnected
0000125314 [ncp.rltk.client] INFO: Try to connect to ssid: NSA_Long
0000125383 [net.lwip_rltk] INFO: is_promisc_enabled
0000125436 [net.lwip_rltk] INFO: get_eap_phase
0000129691 [ncp.rltk.client] INFO: disconnected
0000130240 [ncp.rltk.client] INFO: Try to connect to ssid: NSA_Long
0000130309 [net.lwip_rltk] INFO: is_promisc_enabled
0000130362 [net.lwip_rltk] INFO: get_eap_phase
0000134618 [ncp.rltk.client] INFO: disconnected
0000139633 [ncp.rltk.client] INFO: Try to connect to ssid: NSA_Long
0000139702 [net.lwip_rltk] INFO: is_promisc_enabled
0000139755 [net.lwip_rltk] INFO: get_eap_phase
0000144008 [ncp.rltk.client] INFO: disconnected
0000144557 [ncp.rltk.client] INFO: Try to connect to ssid: NSA_Long
0000144626 [net.lwip_rltk] INFO: is_promisc_enabled
0000144679 [net.lwip_rltk] INFO: get_eap_phase
0000148936 [ncp.rltk.client] INFO: disconnected
0000153951 [ncp.rltk.client] INFO: Try to connect to ssid: NSA_Long
0000154020 [net.lwip_rltk] INFO: is_promisc_enabled
0000154073 [net.lwip_rltk] INFO: get_eap_phase
0000158329 [ncp.rltk.client] INFO: disconnected
0000158878 [ncp.rltk.client] INFO: Try to connect to ssid: NSA_Long
0000158947 [net.lwip_rltk] INFO: is_promisc_enabled
0000159000 [net.lwip_rltk] INFO: get_eap_phase
0000163253 [ncp.rltk.client] INFO: disconnected
0000168300 [ncp.rltk.client] INFO: rltkOff
0000168344 [ncp.rltk.client] INFO: rltkOff done
0000169233 [ncp.rltk.client] INFO: rltkOff
0000169277 [ncp.rltk.client] INFO: rltkOff done
0000169806 [ncp.rltk.client] INFO: Try to connect to ssid: NSA_Long
0000169875 [net.lwip_rltk] INFO: is_promisc_enabled
0000169928 [net.lwip_rltk] INFO: get_eap_phase
0000174182 [ncp.rltk.client] INFO: disconnected
0000174731 [ncp.rltk.client] INFO: Try to connect to ssid: NSA_Long
0000174800 [net.lwip_rltk] INFO: is_promisc_enabled
0000174853 [net.lwip_rltk] INFO: get_eap_phase
0000179107 [ncp.rltk.client] INFO: disconnected
0000184122 [ncp.rltk.client] INFO: Try to connect to ssid: NSA_Long
0000184191 [net.lwip_rltk] INFO: is_promisc_enabled
0000184244 [net.lwip_rltk] INFO: get_eap_phase
0000188499 [ncp.rltk.client] INFO: disconnected
0000189048 [ncp.rltk.client] INFO: Try to connect to ssid: NSA_Long
0000189117 [net.lwip_rltk] INFO: is_promisc_enabled
0000189170 [net.lwip_rltk] INFO: get_eap_phase
0000193426 [ncp.rltk.client] INFO: disconnected
0000198441 [ncp.rltk.client] INFO: Try to connect to ssid: NSA_Long
0000198510 [net.lwip_rltk] INFO: is_promisc_enabled
0000198563 [net.lwip_rltk] INFO: get_eap_phase
0000202817 [ncp.rltk.client] INFO: disconnected
0000203366 [ncp.rltk.client] INFO: Try to connect to ssid:
