Photon 2 VIN pin - help
Hello there! I'm new to all of this and I could really use a helping hand.
I'm currently following a tutorial that instructs me to connect the 5v wire from an LED to the VIN pin on my Photon board. However, I'm using a Photon 2 board and I can't seem to locate a VIN pin on it. Is there any other pin I could connect the wire to instead?
Hi @nacer
For Photon 2, the VUSB pin (3rh pin on the shorter row, counted from the USB side) is the equivalent of the VIN pin mentioned in the tutorial.
You can see the pin functions here Photon 2 datasheet | Reference | Particle
Thank you very much
