Per the topic question, this appears to have a blocking diode between VBAT and VIN (D7).
What about the implications to the RT9526 Charge Controller?
(schematic snippet below)
I don't entirely understand your question. Diode D7 is to block voltage supplied on VUSB from flowing into the battery, bypassing the charge controller.
Because the Photon 2 uses a charge controller, not a full PMIC, there still needs to be a path to allow the battery to power the device, which is through diode D7 in the forward direction.
This is different on devices with a bq24195 PMIC, where the battery only connects to the PMIC, and the PMIC handles whether the battery is charging or discharging and which power source is used.
Thanks for clarifying the D7 role @rickkas7
That makes total sense now with your explanation.
To the original question:
Is there ANY protection for the Photon 2 with reverse polarity voltage on the VBAT/LI+?
Thanks in advance.
The LiPo battery connector does not have reverse polarity protection. Be careful of this because there is no standard for the polarity of the JST-PH connector and many are reversed. See the battery guide for more information.
