Which diode should I use?
So I just burned out another photon by putting the battery in backwards after charging. Can I put a diode between the bat and the photon to guard against this? if so what diode?
thanks steve
@murmsk, how exactly are you connecting the battery to the Photon (which pins)?
The VIN pin
Lots of diode types can be used for wrong polarity protection. I regularly use the B230 (https://www.digikey.com/product-detail/en/diodes-incorporated/B230-13-F/B230-FDICT-ND/815328). Aslo used in many of the particle shields
@murmsk, though @joost provides a good recommendation, the bigger issue is that powering the Photon with a LiPo through a diode to Vin will drop the voltage by 0.5 volts. If you are using a fully charged 3.7v LiPo, the voltage at Vin will be 3.65v or just 0.5v higher than the minimum recommended voltage of 3.6v. It may be better to use a boost regulator to provide 5v to Vin instead OR use an LDO regulator to provide 3.3v directly to the 3V3 pin. You can still use a reverse protection diode with the LDO without “skirting” the minimum voltage requirements.
Slightly OT: I believe that the Photon uses a 100% duty-cycle capable buck converter, meaning that the battery won't actually drop out until it gets to 3.3V, which is like 90% discharged. There's some wiggle room for conditions, but f you boost then buck, or go LDO, you're throwing away more energy in conversion efficiency.
Settle on a connector style and get the correct pin crimper tools. Don't mess around with lithiums and loose wires, it's just going to waste your time when something touches something it shouldn't.
Another solution: https://store.particle.io/products/power-shield-with-headers
