Peculiar Particle Publish Performance
I’ve been using a Webhook forever…
which takes the event value and sends a Pushover notification:
but adding to a new Serial Bridge that I created:
const size_t MAX_MESSAGE_LENGTH = 32;
  Serial1.begin(57600);
  Serial.begin(115200);
  pinMode(D7, OUTPUT);
  digitalWrite(D7, HIGH);
  if(const char* newMessage = checkForNewMessage(Serial1, '\n'))
    Serial1.println(newMessage);
    Serial.println(newMessage);
    Particle.publish("pushover", newMessage, 60, PRIVATE);
    digitalWrite(D7, !digitalRead(D7));
char* checkForNewMessage(Stream& stream, const char endMarker)
  static char incomingMessage[MAX_MESSAGE_LENGTH] = "";
  static byte idx = 0;
  if(stream.available())
    incomingMessage[idx] = stream.read();
    if(incomingMessage[idx] == endMarker)
      incomingMessage[idx] = '\0';
      idx = 0;
      return incomingMessage;
    else
      idx++;
      if(idx > MAX_MESSAGE_LENGTH - 1)
        stream.print(F("{\"error\":\"message too long\"}\n"));  //you can send an error to sender here
        while(stream.available())
          (void)stream.read();
        idx = 0;
  return nullptr;
I am getting:
but the event looks OK:
any suggestions?
turns out my device sends a carriage return and line feed, so I filtered that out the CR and it works a treat:
if (stream.available())
    if (stream.peek() == '\r')
      return nullptr;
