Hello,
I am currently having trouble writing really long strings to a webhook on the particle console. As part of the server side, I need to send a access key that is around 400 characters long. When I hard code the access key into the webhook, everything works fine. But since the access key expires every hour, that is not a viable solution, I need to use {{PARTICLE_EVENT_VALUE}} to send a different access key each time. But when I send the key with particle.publish(), the request fails. Looking at the logs on the particle console, I see the cloud only transfered 256 characters of my access key. Is it possible to send a longer string? Below is my code:
delay(1000);
Serial.println("connecting");
String access_token = "Bearer Atza|IwEBIH9aG4mvW2GYjTu35K_oECPeb7qXumriv5SIFebMRAcFJzoztGQoPjhiOvHXFcqKYtSbxiFWe-20FHJfZ01a_ZYX543PVy-41hrE9u9W-2YvzBlU40iMHjwYPb41LdP6fw66SwePAqTwA1HxB4TQntHlIBX_RpyPHOFKmKtn2LdRWMPcMAeLT0zGmQf_srNgkLtP-YtteADc43kbRbMtgUQPhzRzdeT8N_6zVFSibY2SIM4mye0_KcXRXgUa18s8EMS7PwPZ7xcyD_INxRQvYiifjt8FUJu-y3s4nmExP49dP8nLm1FjEOReZRi89YBBN6-WI1D766CKkLkidl_M70O66qmStiZB77GzrVdtjgGkRHi27krX1KbgQJIkFMPKORv0a_xiX6tuzZOW0JmtjkY8edGJzrlUb7iHC0sDyi9i7dDoYHbVtsDxwFLyTaJ7a3Q";
Serial.println("running");
Particle.publish("drs_replenish_batteries", access_token, PRIVATE);
// Wait 60 seconds
Serial.println("Done.");
delay(6000000);
