PDF in library folder
Hi there,
I want to add data sheet pdf in my library for reference. I’ve created doc folder and put the pdf in it, but after that the “particle library upload” fails with “Unexpected token < in JSON at position 0”.
Does anybody know any workout for that?
Does the upload work without the .pdf?
What is the contents of your library.properties file`?
Yes it works without PDF and I’ve got an answer from support. They know about that problem and offer me to make workaround, to remove PDF temporary when I need to upload lib.
