When I run particle identify, this is what i get.
β ~ particle identify
Serial err: Error: Cannot open /dev/ttyACM0
Serial problems, please reconnect the device.
! serial: Serial problems, please reconnect the device.
Potentially unhandled rejection [2] Error: Serialport not open.
at SerialPortFactory.SerialPort.close (/usr/lib/node_modules/particle-cli/node_modules/serialport/serialport.js:476:17)
at /usr/lib/node_modules/particle-cli/commands/SerialCommand.js:668:16
at runSideEffect (/usr/lib/node_modules/particle-cli/node_modules/when/lib/decorators/flow.js:85:25)
at /usr/lib/node_modules/particle-cli/node_modules/when/lib/decorators/flow.js:80:12
at tryCatchReject (/usr/lib/node_modules/particle-cli/node_modules/when/lib/makePromise.js:845:30)
at runContinuation1 (/usr/lib/node_modules/particle-cli/node_modules/when/lib/makePromise.js:804:4)
at Rejected.when (/usr/lib/node_modules/particle-cli/node_modules/when/lib/makePromise.js:625:4)
at Pending.run (/usr/lib/node_modules/particle-cli/node_modules/when/lib/makePromise.js:483:13)
at Scheduler._drain (/usr/lib/node_modules/particle-cli/node_modules/when/lib/Scheduler.js:62:19)
at Scheduler.drain (/usr/lib/node_modules/particle-cli/node_modules/when/lib/Scheduler.js:27:9)
