I am trying to install the non website compile tool, Particle Dev, and it is failing. It keeps giving me an error on PathTooLong. From a brief internet search It seems that my username for windows is too long and this is causing a problem. Does anyone know a work around?
2016-06-30 17:58:40> Program: Starting Squirrel Updater: --install .
2016-06-30 17:58:40> Program: Starting install, writing to C:\Users\userrr.nameeeeee\AppData\Local\SquirrelTemp
2016-06-30 17:58:40> Program: About to install to: C:\Users\userrr.nameeeeee\AppData\Local\particledev
2016-06-30 17:58:40> CheckForUpdateImpl: Failed to load local releases, starting from scratch: System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Users\userrr.nameeeeee\AppData\Local\particledev\packages\RELEASES'.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at Squirrel.Utility.LoadLocalReleases(String localReleaseFile)
at Squirrel.UpdateManager.CheckForUpdateImpl.<CheckForUpdate>d__3f.MoveNext()
2016-06-30 17:58:40> CheckForUpdateImpl: Reading RELEASES file from C:\Users\userrr.nameeeeee\AppData\Local\SquirrelTemp
2016-06-30 17:58:40> CheckForUpdateImpl: First run or local directory is corrupt, starting from scratch
2016-06-30 17:58:40> ApplyReleasesImpl: Writing files to app directory: C:\Users\userrr.nameeeeee\AppData\Local\particledev\app-1.7.3
2016-06-30 17:59:03> IEnableLogger: Failed to install package to app dir: System.IO.PathTooLongException: The specified path, file name, or both are too long. The fully qualified file name must be less than 260 characters, and the directory name must be less than 248 characters.
at System.IO.PathHelper.GetFullPathName()
at System.IO.Path.NormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths)
at System.IO.Path.GetFullPathInternal(String path)
at ICSharpCode.SharpZipLib.Zip.FastZip.ExtractEntry(ZipEntry entry)
at ICSharpCode.SharpZipLib.Zip.FastZip.ExtractZip(Stream inputStream, String targetDirectory, Overwrite overwrite, ConfirmOverwriteDelegate confirmDelegate, String fileFilter, String directoryFilter, Boolean restoreDateTime, Boolean isStreamOwner)
at Squirrel.UpdateManager.ApplyReleasesImpl.<>c__DisplayClassb4.<<installPackageToAppDir>b__ad>d__bd.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at Squirrel.Utility.<LogIfThrows>d__50`1.MoveNext()
2016-06-30 17:59:03> Unhandled exception: System.AggregateException: One or more errors occurred. ---> System.IO.PathTooLongException: The specified path, file name, or both are too long. The fully qualified file name must be less than 260 characters, and the directory name must be less than 248 characters.
at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
at Squirrel.UpdateManager.ApplyReleasesImpl.<ApplyReleases>d__7a.MoveNext()
at Squirrel.UpdateManager.<FullInstall>d__f.MoveNext()
at Squirrel.Update.Program.<Install>d__38.MoveNext()
--- End of inner exception stack trace ---
at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
at System.Threading.Tasks.Task.Wait()
at Squirrel.Update.Program.executeCommandLine(String[] args)
at Squirrel.Update.Program.main(String[] args)
---> (Inner Exception #0) System.IO.PathTooLongException: The specified path, file name, or both are too long. The fully qualified file name must be less than 260 characters, and the directory name must be less than 248 characters.
at Squirrel.Update.Program.<Install>d__38.MoveNext()<---
2016-06-30 18:00:00> Program: Starting Squirrel Updater: --install .
2016-06-30 18:00:00> Program: Starting install, writing to C:\Users\userrr.nameeeeee\AppData\Local\SquirrelTemp
2016-06-30 18:00:00> Program: About to install to: C:\Users\userrr.nameeeeee\AppData\Local\particledev
2016-06-30 18:00:00> Program: Install path C:\Users\userrr.nameeeeee\AppData\Local\particledev already exists, burning it to the ground
2016-06-30 18:00:01> CheckForUpdateImpl: Failed to load local releases, starting from scratch: System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Users\userrr.nameeeeee\AppData\Local\particledev\packages\RELEASES'.
2016-06-30 18:00:01> CheckForUpdateImpl: Reading RELEASES file from C:\Users\userrr.nameeeeee\AppData\Local\SquirrelTemp
2016-06-30 18:00:01> CheckForUpdateImpl: First run or local directory is corrupt, starting from scratch
2016-06-30 18:00:01> ApplyReleasesImpl: Writing files to app directory: C:\Users\userrr.nameeeeee\AppData\Local\particledev\app-1.7.3
2016-06-30 18:00:21> IEnableLogger: Failed to install package to app dir: System.IO.PathTooLongException: The specified path, file name, or both are too long. The fully qualified file name must be less than 260 characters, and the directory name must be less than 248 characters.
2016-06-30 18:00:21> Unhandled exception: System.AggregateException: One or more errors occurred. ---> System.IO.PathTooLongException: The specified path, file name, or both are too long. The fully qualified file name must be less than 260 characters, and the directory name must be less than 248 characters.
2016-06-30 18:01:52> Program: Starting Squirrel Updater: --install .
2016-06-30 18:01:52> Program: Starting install, writing to C:\Users\userrr.nameeeeee\AppData\Local\SquirrelTemp
2016-06-30 18:01:52> Program: About to install to: C:\Users\userrr.nameeeeee\AppData\Local\particledev
2016-06-30 18:01:52> Program: Install path C:\Users\userrr.nameeeeee\AppData\Local\particledev already exists, burning it to the ground
2016-06-30 18:01:53> CheckForUpdateImpl: Failed to load local releases, starting from scratch: System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Users\userrr.nameeeeee\AppData\Local\particledev\packages\RELEASES'.
2016-06-30 18:01:53> CheckForUpdateImpl: Reading RELEASES file from C:\Users\userrr.nameeeeee\AppData\Local\SquirrelTemp
2016-06-30 18:01:53> CheckForUpdateImpl: First run or local directory is corrupt, starting from scratch
2016-06-30 18:01:53> ApplyReleasesImpl: Writing files to app directory: C:\Users\userrr.nameeeeee\AppData\Local\particledev\app-1.7.3
2016-06-30 18:02:13> IEnableLogger: Failed to install package to app dir: System.IO.PathTooLongException: The specified path, file name, or both are too long. The fully qualified file name must be less than 260 characters, and the directory name must be less than 248 characters.
2016-06-30 18:02:13> Unhandled exception: System.AggregateException: One or more errors occurred. ---> System.IO.PathTooLongException: The specified path, file name, or both are too long. The fully qualified file name must be less than 260 characters, and the directory name must be less than 248 characters.
2016-06-30 18:08:08> Program: Starting Squirrel Updater: --install .
2016-06-30 18:08:08> Program: Starting install, writing to C:\Users\userrr.nameeeeee\AppData\Local\SquirrelTemp
2016-06-30 18:08:08> Program: About to install to: C:\Users\userrr.nameeeeee\AppData\Local\particledev
2016-06-30 18:08:08> Program: Install path C:\Users\userrr.nameeeeee\AppData\Local\particledev already exists,
