ParticleDev fails during run, install and uninstall
ok, so i had ParticleDev installed and running. V1.5.1.
When I came back to it after a day it no longer launches. I get the wait cursor for 2 seconds, then nothing.
I try to uninstall and I nothing happens, no errors that I know how to find.
when i install again from here: https://www.particle.io/dev I get the following errors in the log:
It says it cant find the path, but it is there are privs are ok.
If i download the zip from github and just run atom.exe it works fine.
Any ideas?
2016-03-31 22:03:56> Program: Starting Squirrel Updater: --install .
2016-03-31 22:03:56> Program: Starting install, writing to C:\Users\jonva\AppData\Local\SquirrelTemp
2016-03-31 22:03:56> Program: About to install to: C:\Users\jonva\AppData\Local\particle
2016-03-31 22:03:56> CheckForUpdateImpl: Failed to load local releases, starting from scratch: System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Users\jonva\AppData\Local\particle\packages\RELEASES'.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
   at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
   at Squirrel.Utility.LoadLocalReleases(String localReleaseFile)
   at Squirrel.UpdateManager.CheckForUpdateImpl.<CheckForUpdate>d__3d.MoveNext()
2016-03-31 22:03:56> CheckForUpdateImpl: Reading RELEASES file from C:\Users\jonva\AppData\Local\SquirrelTemp
2016-03-31 22:03:56> CheckForUpdateImpl: First run or local directory is corrupt, starting from scratch
2016-03-31 22:03:57> ApplyReleasesImpl: Writing files to app directory: C:\Users\jonva\AppData\Local\particle\app-1.5.1
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\d3dcompiler_47.dll to C:\Users\jonva\AppData\Local\particle\app-1.5.1\d3dcompiler_47.dll
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\content_resources_200_percent.pak to C:\Users\jonva\AppData\Local\particle\app-1.5.1\content_resources_200_percent.pak
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\atom.exe to C:\Users\jonva\AppData\Local\particle\app-1.5.1\atom.exe
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\content_shell.pak to C:\Users\jonva\AppData\Local\particle\app-1.5.1\content_shell.pak
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\icudtl.dat to C:\Users\jonva\AppData\Local\particle\app-1.5.1\icudtl.dat
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\libEGL.dll to C:\Users\jonva\AppData\Local\particle\app-1.5.1\libEGL.dll
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\libGLESv2.dll to C:\Users\jonva\AppData\Local\particle\app-1.5.1\libGLESv2.dll
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\LICENSE to C:\Users\jonva\AppData\Local\particle\app-1.5.1\LICENSE
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\msvcp120.dll to C:\Users\jonva\AppData\Local\particle\app-1.5.1\msvcp120.dll
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\msvcr120.dll to C:\Users\jonva\AppData\Local\particle\app-1.5.1\msvcr120.dll
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\natives_blob.bin to C:\Users\jonva\AppData\Local\particle\app-1.5.1\natives_blob.bin
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\node.dll to C:\Users\jonva\AppData\Local\particle\app-1.5.1\node.dll
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\pdf.dll to C:\Users\jonva\AppData\Local\particle\app-1.5.1\pdf.dll
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\squirrel.exe to C:\Users\jonva\AppData\Local\particle\app-1.5.1\squirrel.exe
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\vccorlib120.dll to C:\Users\jonva\AppData\Local\particle\app-1.5.1\vccorlib120.dll
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\snapshot_blob.bin to C:\Users\jonva\AppData\Local\particle\app-1.5.1\snapshot_blob.bin
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\ui_resources_200_percent.pak to C:\Users\jonva\AppData\Local\particle\app-1.5.1\ui_resources_200_percent.pak
2016-03-31 22:04:02> ApplyReleasesImpl: Moving file C:\Users\jonva\AppData\Local\particle\app-1.5.1\lib\net45\xinput1_3.dll to C:\Users\jonva\AppData\Local\particle\app-1.5.1\xinput1_3.dll
2016-03-31 22:04:02> ApplyReleasesImpl: Squirrel Enabled Apps: [C:\Users\jonva\AppData\Local\particle\app-1.5.1\atom.exe]
2016-03-31 22:04:06> ApplyReleasesImpl: Starting fixPinnedExecutables
2016-03-31 22:04:06> ApplyReleasesImpl: fixPinnedExecutables: oldAppDirectories is empty, this is pointless
2016-03-31 22:04:06> ApplyReleasesImpl: Fixing up tray icons
2016-03-31 22:04:06> ApplyReleasesImpl: cleanDeadVersions: for version 1.5.1
2016-03-31 22:04:06> ApplyReleasesImpl: cleanDeadVersions: exclude folder app-1.5.1
2016-03-31 22:04:08> InstallHelperImpl: Couldn't write uninstall icon, don't care: System.Net.WebException: The remote server returned an error: (404) Not Found.
   at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
   at System.Net.WebClient.GetWebResponse(WebRequest request, IAsyncResult result)
   at System.Net.WebClient.DownloadBitsResponseCallback(IAsyncResult result)
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
   at Squirrel.UpdateManager.InstallHelperImpl.<CreateUninstallerRegistryEntry>d__126.MoveNext()
