Can't install Particle Dev - path exception thrown?
It’s been a few months since I used Particle Dev, and I noticed it wasn’t logging into the cloud, so I downloaded the latest copy (ParticleDevSetup.exe 1.8.0) and tried to install it. The installer crashed and provided the following “SquirrelSetup.log” file. I uninstalled my existing copy and atom, rebooted, and I get the same problem when running the installer. The .msi file just crashes with no response. Seems like some path being specified is too long. What’s up?
2017-03-19 19:15:54> Program: Starting Squirrel Updater: --install .
2017-03-19 19:15:54> Program: Starting install, writing to C:\Users\Jeremy Williams\AppData\Local\SquirrelTemp
2017-03-19 19:15:54> Program: About to install to: C:\Users\Jeremy Williams\AppData\Local\particledev
2017-03-19 19:15:54> CheckForUpdateImpl: Failed to load local releases, starting from scratch: System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Users\Jeremy Williams\AppData\Local\particledev\packages\RELEASES'.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
   at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
   at Squirrel.Utility.LoadLocalReleases(String localReleaseFile)
   at Squirrel.UpdateManager.CheckForUpdateImpl.<CheckForUpdate>d__3f.MoveNext()
2017-03-19 19:15:54> CheckForUpdateImpl: Reading RELEASES file from C:\Users\Jeremy Williams\AppData\Local\SquirrelTemp
2017-03-19 19:15:54> CheckForUpdateImpl: First run or local directory is corrupt, starting from scratch
2017-03-19 19:15:54> ApplyReleasesImpl: Writing files to app directory: C:\Users\Jeremy Williams\AppData\Local\particledev\app-1.8.0
2017-03-19 19:16:13> IEnableLogger: Failed to install package to app dir: System.IO.PathTooLongException: The specified path, file name, or both are too long. The fully qualified file name must be less than 260 characters, and the directory name must be less than 248 characters.
   at System.IO.PathHelper.GetFullPathName()
   at System.IO.Path.LegacyNormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths)
   at System.IO.Path.NormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths)
   at System.IO.Path.GetFullPathInternal(String path)
   at ICSharpCode.SharpZipLib.Zip.FastZip.ExtractEntry(ZipEntry entry)
   at ICSharpCode.SharpZipLib.Zip.FastZip.ExtractZip(Stream inputStream, String targetDirectory, Overwrite overwrite, ConfirmOverwriteDelegate confirmDelegate, String fileFilter, String directoryFilter, Boolean restoreDateTime, Boolean isStreamOwner)
   at Squirrel.UpdateManager.ApplyReleasesImpl.<>c__DisplayClassb4.<<installPackageToAppDir>b__ad>d__bd.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at Squirrel.Utility.<LogIfThrows>d__50`1.MoveNext()
2017-03-19 19:16:13> Unhandled exception: System.AggregateException: One or more errors occurred. ---> System.IO.PathTooLongException: The specified path, file name, or both are too long. The fully qualified file name must be less than 260 characters, and the directory name must be less than 248 characters.
   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
   at Squirrel.UpdateManager.ApplyReleasesImpl.<ApplyReleases>d__7a.MoveNext()
   at Squirrel.UpdateManager.<FullInstall>d__f.MoveNext()
   at Squirrel.Update.Program.<Install>d__38.MoveNext()
   --- End of inner exception stack trace ---
   at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
   at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
   at System.Threading.Tasks.Task.Wait()
   at Squirrel.Update.Program.executeCommandLine(String[] args)
   at Squirrel.Update.Program.main(String[] args)
---> (Inner Exception #0) System.IO.PathTooLongException: The specified path, file name, or both are too long. The fully qualified file name must be less than 260 characters, and the directory name must be less than 248 characters.
   at Squirrel.Update.Program.<Install>d__38.MoveNext()<---
For what it’s worth, I was able to extract particle-dev-windows-1.8.0.zip and avoid the installer.
